i am putting22" tires on the back for the winter because i will be doing alot of trail riding in the snow. so my question is what size front sprocket should i put on it to make up for the bigger tires so its geared like stock? i have 14/41 right now
you could put a 13 tooth on the front and it should put you close to where you are now assuming you have 20s now
i go 22/12/9's on mine sittin @ 49" and it does friggin awesome! :evil: stock gearing and i'm power sliddin uver mougles in third, takes the tight trails etc. just fine. i started out slow, but found it ripps with great stability, and takes all i give it.
Where did you buy the sticker in your sig!!!!!!!!!!
