BlasterKX Posted November 29, 2008 Report Posted November 29, 2008 (edited) is there by chance a in line filter between ur gas tank and the carbs?? and make sure ur rubber line for ur choke isnt rotted our missing.(it could cause something) also make sure ur silver tips on top of the spark plugs arent loose and ur spark plug boots arent loose ether. Edited November 29, 2008 by BlasterKX Quote
firebanshee Posted November 29, 2008 Report Posted November 29, 2008 Yes, I have tors..... should they on a certain setting? You can eliminate the tors electronically by unplugging the brain box to it,the box is a little square box under the left side of the fuel tank with 3 wires going to it up by the coils .Just unplug it and it will dissable the system and you can get a removal kit later.You can also switch your spark plug wires and see if the miss follows the plug wire, you cannot cross the plug wires on a stock banshee ignition system because they both fire at the same time every time. Quote
forSHEEzee Posted August 11, 2009 Report Posted August 11, 2009 I have the same problem going on right now with my machine. Did you ever get this fixed? What was the problem If you did? Quote
