OKCterror Posted November 11, 2008 Author Report Share Posted November 11, 2008 trip to redlight dist- $20 to fill up cheap motel- $15/hr hooker- $30 getting small pets that like to pop up and say hi- awesome explaining to the wife- leaving that to chance.lol. Quote Link to comment Share on other sites More sharing options...
killshee Posted November 11, 2008 Report Share Posted November 11, 2008 i would go with stroker and cool head then pipes and port later.... Quote Link to comment Share on other sites More sharing options...
KEVSWS6 Posted November 11, 2008 Report Share Posted November 11, 2008 Shearer in frames and a mid to top end port job with a timing plate. This will make more power than any other combo for that amount of money and includes shipping. Quote Link to comment Share on other sites More sharing options...
screamin_banshee_2003 Posted November 11, 2008 Report Share Posted November 11, 2008 nothing like a 4 mil hot rod crank with a matched port. u will feel the diffrence instantly. later some pipes t5 or cpi, 33 pwk carbs and boss intake . ur shee will be illegal to dune with killer speed :cool: Quote Link to comment Share on other sites More sharing options...
okbeast Posted November 11, 2008 Report Share Posted November 11, 2008 Shearer in frames and a mid to top end port job with a timing plate. This will make more power than any other combo for that amount of money and includes shipping. Kev's dune port ran frickin awesome when I had it with Shearers. On another note: I have some CPI inframes for sale, I'm up in Stillwater and come through OKC often. Lmk. Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 11, 2008 Author Report Share Posted November 11, 2008 This is what i got for now. Gonna slap em in and then ship the jugs. Quote Link to comment Share on other sites More sharing options...
lilmegill727 Posted November 12, 2008 Report Share Posted November 12, 2008 This is what i got for now. Gonna slap em in and then ship the jugs. looks like you picked up some goodies. what no shearers or cpis to go with that nice port job? Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 12, 2008 Author Report Share Posted November 12, 2008 soon young jedi.lol. Quote Link to comment Share on other sites More sharing options...
desertdeweller Posted November 12, 2008 Report Share Posted November 12, 2008 I would agree with the 4 mil and port work. get your internals taken care of then you can play with bolt ons later. If you go into to do a stroker it only makes sence to port it at the same time since you have to pull the motor apart any ways. You already have the basics covered they can easil be upgraded down the road. Quote Link to comment Share on other sites More sharing options...
dirtfreak Posted November 12, 2008 Report Share Posted November 12, 2008 the cool head is a good choice cooler means power if your gonna run it for long periods of time.plus you can switch the domes for pump or race fuel.stroker crank and shearer pipes and all that sounds wonderful but for 900 unless your doing all the work your self isnt gonna b enough money.i say advance your timing bore your cylinders to some pro-lite pistons then port the cylinder all at the same time.the reason you want to bore and do the pistons is if you port now and later need to bore and install the pro-lites you will loose some performance from the port work,someone correct me if im wrong.a good port job will add more power than a stroker crank shearer pipes or any or the other mods.but if you had it all it would make more of a difference but remember you where talking about 900$.you can save your cash and do it all or i would just advance your timing bore pro-lites good port job get it jetted and tuned right and you will be head over hills faster than you are now,along with your cool head you already have.youll be much faster and will b able to do it all for the money your wanting to spend.oh if you decide to go with a stroker crank go with the hotrods crank and not the vito's. Quote Link to comment Share on other sites More sharing options...
dirtfreak Posted November 12, 2008 Report Share Posted November 12, 2008 i 4 got to mention after you get you shee ported you will need a clutch theres another 100 there.i recommend a clutch kit from F.A.S.T. best clutch money can buy for the price and way cheaper than a lockup set up by far.this is the clutch i run with a +6 swinger and 2nd gear hole shots has held up well. Quote Link to comment Share on other sites More sharing options...
Hilarious Posted November 12, 2008 Report Share Posted November 12, 2008 This is what i got for now. Gonna slap em in and then ship the jugs. how much that billet timing plate set ya back? around 80 bucks? you could have gotten the cheaper rickystator plate and taken the difference and put that in a pancake bearing on your clutch adjuster. you will have the clutch cover off to put that impeller in anyway. just a thought, i know i am replying a bit to late here. lol Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 13, 2008 Author Report Share Posted November 13, 2008 how much that billet timing plate set ya back? around 80 bucks?you could have gotten the cheaper rickystator plate and taken the difference and put that in a pancake bearing on your clutch adjuster. you will have the clutch cover off to put that impeller in anyway. just a thought, i know i am replying a bit to late here. lol got it for 80,lol, i installed the impellar, stator to +4 removed the old reeds and started to cut the intakes, installed the new pet-cock, and removed the old head. Just gotta tie up loose ends and install the new head tomorrow. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted November 13, 2008 Report Share Posted November 13, 2008 Use some vasoline on the orings to help hold them in place. Take the water fitting of the back of the head too. That way your not fighting the radiator hose and trying to keep all the orings in place at the same time. Once you get the head snuged down put the rear water inlet fitting in to the hose then bolt it back on the head. Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 16, 2008 Author Report Share Posted November 16, 2008 Got it all done and tuned it, its a totally dif machine. Pulls the wheels threw 4th and will spin threw 3rd.lol. Gonna strap the plastic on tomorrow. Quote Link to comment Share on other sites More sharing options...
