lilnomad Posted October 31, 2008 Report Posted October 31, 2008 What oil do you put in your case(and how much),what oil do you mix with your gas, and what spark plugs??thanks Quote
05.Banshee.SE Posted October 31, 2008 Report Posted October 31, 2008 GearSaver for the case, Yamalube or (my new favorite) Castor 927. I run 32:1 mix (4 oz per gallon). NGKBR8ES plugs. Look in the manual for the case amount, I forget. I filled it with 2 jugs, but idk what size they were now. Quote
Washburn Posted October 31, 2008 Report Posted October 31, 2008 (edited) I buy Motorex fully synthetic 10w30 and I fill the crank case with a bottel and a half. Thats 1.5 the manual calls for 1.6 Oh yeah Castor 927 for premix at 32:1 Edited October 31, 2008 by Washburn Quote
LiftdT4R Posted October 31, 2008 Report Posted October 31, 2008 One of those questions that never gets old..... You might want to try using the search button next time. This topic has been covered a gazilllion times. Quote
Bansh-eman Posted October 31, 2008 Report Posted October 31, 2008 ATF Type F for Tranny. Yamalube 36:1 for gas Klotz super techniplate 32:1 Alky NGK B8ES on gas NGK BR8ES if running a dynatek NGK B9ES Alky NGK BR9ES Running dynatek NGK B9EVG (irridium) running PVL Quote
locogato11283 Posted November 1, 2008 Report Posted November 1, 2008 just cheap ass 10w-40 motor oil for the tranny and klotz at 50;1 for the cylinders. Quote
THE GRIM RIPPER Posted November 1, 2008 Report Posted November 1, 2008 10w 30 - Amsoil Injector Amsoil huh???? High Roller, When your buyin steaks.... I bet your spring for the Angus Quote
