skinindustries Posted October 28, 2008 Report Posted October 28, 2008 Ok my right carb ia opening a little more then my left one is that normal? And there is like a little bottle that says coolent on it under my seat is that like a catch tank for overflow and can I take it out with no side effects? Quote
shee4speed Posted October 28, 2008 Report Posted October 28, 2008 sound like you need to sync your carbs cick here The overflow bottle is not required.Alot of guys(including myself) have eliminated it and ran the overflow tube down the frame,to just drain on the ground. Quote
skinindustries Posted October 28, 2008 Author Report Posted October 28, 2008 Ok stupid question how do you sync up the carbs? I'm new to the banshee and do you still keep the thing for overflow in the cylinder head and just zip tie it to the frame Quote
maxtrax Posted October 29, 2008 Report Posted October 29, 2008 I just moved my coolant overflow up into the nose of my shee. It is under the front plastic, between the bumper and the radiator. Just use the same tube (trim it of course) and use two heavy zip-ties to attach it to the frame. As far as the tube from the cylinder head. That should have a tube to the radiator. >>There is a link above on how to sync your carbs (or to get it close remove your air filters and watch the slides. They should both reach the top at the exact same time.) Hope that helps you Quote
vulvafan537240 Posted October 29, 2008 Report Posted October 29, 2008 sound like you need to sync your carbs cick here The overflow bottle is not required.Alot of guys(including myself) have eliminated it and ran the overflow tube down the frame,to just drain on the ground. cick here this is the link to sync your carbs Quote
dragbanshee Posted October 29, 2008 Report Posted October 29, 2008 cick here this is the link to sync your carbs hmmm.... Quote
