As Kevin Herr once told me, anything lower than 105, it is time to rebuild. Should be around 121 on a stock head. So your WAY below that. With it being that low, you should notice running issues. Have you had any? If not I would try a diff tester.
If you still need it, might as well send it off for port and rebuild like J.B said.
Thats really low like they said i think it should be like 120-125 stock. So try a defferent tester and if its the same get it rebuilt, like they said above if its apart you should get it ported, because you will want to sooner or later
If you actually had 53 pis, you wouldnt be able to start it, and the bike would run like real shit. Anything below 90 your going to start to notie really quick.
Your doing something wrong or your comp testor is broekn.
Are you kicking it until it stops going up?
ya thanks im going to get another tester and try again
