bad ass camaro
Everything posted by bad ass camaro
  1. does enyone know if its ok to stand a yfz up on the rear tires to transport it? I was told that oil will drain into the air box, it so whats the trick .
  2. i just talked to yamaha and they think i might have a leak in the bottom end so im going to get a presure test done
  3. my elevation is 500 ft. when i had 320 main in it the plug burned up within 1/4 mile really white dry faul. had lots of power befor it burned up tho.i put 380 in it and plug color was good but isnt running good in the bottom and mid. im thinking that i might have a air leak somewhere . so if i spray starting fluid around all the carb boots and head will that tell me if there is a leak,or not? i have k&n pod filters.
  4. ok i have toomey pipes and k&n with stock complete rebuilt motor and 320 mains dry faul the plugs i put 380 main in and it has plug color and runs good but i feel something is wrong
  5. HAY HOW MENY NOTCHES ARE ON A STOCK BANSHEE NEEDLE, I HAVE 6 AND PEOPLE TELL ME THAT IT SHOULD BE 5.
  6. ya thanks im going to get another tester and try again
  7. yes has a hard time in mid range but once it gets going it runs good. idles great starts great
  8. i have 52 lbs of compression it seems low but i dont know
