ATV_hub
    3
Everything posted by ATV_hub
  1. Does it really matter? I’m not concerned about where it comes from as long as it’s reliable. The price was right and the quality is good, ima run it!
  2. Pwk 28 flat slides, my jetting is 150main 50 pilot and jjh needle middle clip I agree, you don’t ‘need’ them but they are very nice carbs. I would never go back to stock. -Ben
  3. I have a set on mine, now that I know what they’re like I would definitely buy them again, easier to tune, better throttle response, smoother, stronger power. My bike is noticeably sharper with them on it. -Ben
  4. I would say about 145 is somewhere close to 260 for a banshee (at a guess) but start a few sizes higher and only drop one size at a time. -Ben
  5. There is no explaining, they’re just different Also, that sounds like a crazy big jump in jetting. But if you want a reference my jetting for pwk 28’s is 150 main 50 pilot, jjh needle on the middle clip (If I remember correctly). All my mods are listed. -Ben
  6. Definitely get rid of those yfz shocks. I would not call it a mx build with those on it, they are far too stiff and will cause huge arm pump after a few laps. The yfz shocks are longer and might have more sag making it more difficult to lift the front end, your rear shock might also be soft and soaking up some of the power. It is a strong possibility that you have excess caster, and this may be the reason it feels unstable at high speeds, it’s a trade off, low speed agility vs high speed stability. Do your upper a arms have spacers on one side? If you plan on hitting jumps and whoops you should really look for a shock with high speed compression adjustment, but the float 3’s should be a big improvement over standard yfz shocks -Ben
  7. And also a serial number on the body just above the float bowl?
  8. Based on your description it sounds like you got the knock offs from BP racing, what is your jetting? -Ben
  9. For another $300 you can get fox float 3’s and some piece of mind or you could buy a used pair. Cheeping out on eBay shocks is not worth it IMO. -Ben
  10. While your in there you could block off this breather and plug the hole for the hose with some black silicone. It was used for the 2t oil pump on the rd/rz 350. The brass nipple presses out (from the outside in) you can make or buy a block off plate that screws in to those 2 holes. It’s not necessary but it’s a much cleaner set up. -Ben
  11. Yes, it is, the bushings are cheap to replace
  12. The scuffing is normal, I presume Yamaha do it to balance or just to clean up the casting, the kicker assay has play as you removed the cover, the cover supports the shaft. -Ben
  13. If you used one of those carb rebuild kits I would put back in the old jets. it is almost certain the jets in the kit will not be the same size as the jetting you had. If you used a kit, put back in your old jets and try again. -Ben
  14. Let us know how it goes, there are no reviews of kased plates on here yet and I haven’t tried them personally but they look good -Ben
  15. price it up and see what will be the best option, imo I would avoid trying to retrofit shocks from a different machine
  16. yes, you save some cash in the package deal, I believe the legacy series shocks that come in the deal have steel bodies, something you might want to consider as they will be heavier and could chip and rust if you race and get roosted. -Ben
  17. I have been using an ebay stator for the past year that came with a 2 year warranty as my oem stator tested good but the poles were badly corroded so i am keeping it as a spare. I had to solder the plug connections as they were just crimped. but other than that it has been flawless. Might be an option for any european members viewing this thread as getting an oem (new or used) shipped from the states can be expensive. -Ben
  18. Similarly to loco, I have lt alba arms also. I have ran them for 5 years before I had to replace the bushings, if you look after your stuff and do the correct maintenance alba are fine. Would I prefer fireball or roll? Yes, but I don’t have any complaints about the alba arms, they are very good value. -Ben
  19. If you are looking to port stock cylinders there are a number of extremely experienced engine builders in the uk. John Floyd of Floydy racing would definitely be able to port your stock cylinders or set you up with any cylinders or crank. His cylinders hold some British records I believe. -Ben
  20. Kased plates make plastic skid plates for the banshee
  21. is the packing in your silencers good?
