Mxjd619
1 Follower
About Mxjd619
  • Birthday 07/10/1988
    Rochester, Ny
  • Interests
    Snowboarding, motocross, working out, hunting
    2004 banshee. In middle of rebuild. Crashed the wild beast. New paint, plastics, top end. Hopefully done by summer.
Recent Profile Visitors
1,381 profile views
Mxjd619's Achievements
  1. So I took the stator apart to look for physical damage and try to find a cause for failure, also just gain more knowledge on this topic while I'm at it. Everthing looks pretty good. I tested continuity from the ends of the red and green wire to were they actually connect to the stator and it both showed good. Does this mean there is some sort of break or more realistically a short in the actual wrapping ?
  2. Need a Stator! Anyone!
  3. Mxjd619
    WTB OEM STATOR
    Hey guys throwing it out there. Who has an OEM stator that they wanna part with? I know someone out there has one laying around.
  4. is there a way i can test continuity for the stator ignition side then ? the lighting side which i believe are the white wires with traces show good, but i am told these are completely separate from each other correct?
  5. Hey guys, just finished my complete rebuild but i have no spark. My question is should i have continuity when i test the stator red and green wires on the plug end? Even if it shows incorrect ohms should i have continuity or will both ohms and continuity show bad? id rather fix a bad connection to the stator then replace it. Thanks for the help
  6. This is the strangest conversation about radiators Ive ever read.
  7. ^^ well said
  8. Thats a nice mx build man, very well done.
  9. There at the shop now. This guy does alot of the bikes at the track. Hes an older dude, has built some fast engines. I will def be looking them over for my own piece of mind though. Ill keep ya posted
  10. looks like FMF with diff tips like zilla said
  11. Just deopped off cylinders to shop, bore job and piston, woop woop
  12. Im a satin fan myself but either will probably look good. I had a swing arm painted black (gloss) with purple and it looked sick.
  13. If you can get another picture of these i might be interested in taking them off youre hands
  14. those look nice man
