PaymentPlan
    7
Everything posted by PaymentPlan
  1. I texted you some details. Sent from my SM-G950U using Tapatalk
  2. 10-4. I'll get you sent out Friday. Sent from my SM-G950U using Tapatalk
  3. Additional pictures can be requested. Sent from my SM-G950U using Tapatalk
  4. PM me if interested. Prices do not reflect shipping. Lower rear fender brackets $10 Grab bar rear fender brackets $10 Rear brake pusher and res $15 Precut vent tubing from Cascade Innovations $8 per pack Bulk vent tubing $3 per foot, either size tube. Tubing will ship as one piece so you can cut yourself. - 4 mm I.D. 7 mm O.D. for carburetor vents - 3 mm I.D. 5 mm O.D for the float bowl overflow Honda 400EX thumb throttle housing $30 - Welded additional aluminum so you can open up 39 pwk's. This will need some grinding to finish it and use properly. OEM new right side cover $40 Lower motor tension rods with all hardware $30 Rear brake pedal $15 Dual pingle valve $60 Powder coated YFZ450R front brake calipers $40 - Need new seals and a cleaning Pro design tether $15 Powermadd handguards $30 - Hand guards only, no mounting hardware Pro taper pad cover $5
  5. Thanks, I should of updated this. West Coast ATV got me hooked up with all that I needed. Sent from my SM-G950U using Tapatalk
  6. Looking for these tabs circled in blue. Maybe you have a junk frame laying around that has these. Willing to pay $40 if their cut off correctly and don't have tube length cut off. Dont care if their rusty, going to be powder coated anyways. Sent from my SM-G950U using Tapatalk
  7. What color u have now
  8. What ones you looking for?
  9. Photos and price.
  10. 10-4 good buddy
  11. Looking for the 2 lower motor mount tension rods. You can post pics or send PM. Thanks
  12. Happens all the time. There's a bike on CL local to me for $4450. Same bike was on ebay last week bidding at $7,500. It never sold. A lot of people are smoking crack cocaine when they list their bikes up for sale.
  13. He would be better off removing the plastics then drilling.
  14. https://www.ebay.com/itm/2006-Yamaha-Banshee-Special-Edition-Super-Clean/123767148852?hash=item1cd118d134:g:hJ0AAOSw2zZc1jeB Heck yeah, just drill some holes in my frame, dont need that support there.
  15. I'm going to make a change here to avoid confusion. Price is $3 per foot for any size tube. Once I install these hoses on my bike I'll post how much length was required so you know what your bike will need. Sent from my SM-G950U using Tapatalk
  16. Cool, so 2 banshee carbs, one cr, and one klx then?
  17. I did some investigating on the clear pink vent tubing that powersport OEM's and or Keihin uses on their carburetors from the factory. Oddly enough, it was a little difficult to find. Most of what you will come across when looking for vent tubing are pre-cut pieces, which is annoying if your trying to have all of your tube ends meet together at the same point for a clean look. I ended up finding a source that supplies the big 4 out of Japan. I ordered 2 reels, the minimum length you could purchase is 50 meters, or 164 feet. Ive got 4mm I.D. 7mm O.D. for every connection on your carb besides the float bowl overflow. Then 3mm I.D. 5mm O.D. for the float bowl overflow. Once it arrives I will do some measurements and cut one long piece of each size to redo a set of carbs or one carb if you specify. Probably 10 feet of the thicker tube and 3 feet of the smaller stuff? Just rough guess right now. $30 for both carbs plus free shipping in the states, or $20 for one. Ill post pictures of the stuff when it comes in. If your interested shoot me a PM or comment and I will reserve you some. Thanks
  18. Spot on with your last paragraph. Agree 100%.
  19. https://detroit.craigslist.org/okl/snw/d/bloomfield-hills-2006-yamaha-banshee/6880199126.html
  20. 40:1 is my preference.
  21. Care to share a close up photo of that rear brake Master Cylinder and reservoir?
  22. PM sent
