Spiner
Everything posted by Spiner
  1. Possible postage to Ireland?
  2. Got it shipped from England.
  3. It worked , thanks. PS : The filter is drying from motor oil.
  4. Thanks for the tips , will definetley try when I can't get the offical Oil.
  5. You sure it will work? Dont wan't to fu*k up my filter/engine.
  6. I will ask tomorrow at my local car shop if they have anything similar. PS : Sry for the double post.
  7. No ;(
  8. I have to bring it out on Saturday , meet up. I have to import it from England , that will take about 1 week ;/ Here in Ireland you can't get anything locally.
  9. Is it okay to put some silicone oil (for airsoft guns) on my K&N air filter? Or should I just run without the oil on the filter until I get it shipped? PS : This is the spray [LINK]
  10. Is it okay to put some silicone oil (for airsoft guns) on my K&N air filter? Or should I just run without the oil on the filter until I get it shipped?
    1. BurnsideBanshee
      BurnsideBanshee
      Just use a light coat of motor oil.
    2. BurnsideBanshee
      BurnsideBanshee
    3. trickedcarbine
      trickedcarbine
      NEEDS to be a very liight oil. Probably be best to just wait. However, i have seen guys use a light mist of WD-40
  11. Haha , Good one
  12. Thanks , for the tires I use water + soft sponge , If the mud is dry I use my foot + water. Btw.To clean under the engine I used some truck washing detergent that my Father got me
  13. Thanks , I'm very happy now Just started it again on cold , 1st kick like it used to be. Although it would be nice to know what was causing the issue.
  14. Fuel. It started without any trouble today , don't know what's up but when I drove it , it had no power , after about 2 minutes of drive , everything is back to normal now.
  15. Compression is good , not that problem , when the engine is running and I pull the choke out it dies too.Engine warm no problem starting , idles great.
  16. Got my banshee out yesterday and tried to start it , wouldn't start at all so I push started it , ran perfect.When I turned the engine off to put fuel and wash my glasses out I thought it won't start , but it started like it used to do(engine was still warm). Today it wouldn't start on cold engine , push started it and runs perfect , starts on warm engine no problem. One of my spark plug wires is broken but I put it back into place and secured it. Also when I turn the choke on the quad slowly dies , the rev's go down until it bogs down? Any help? Will be very grateful for help.
  17. Then what should I look for?
  18. LOL The closest I can get Razr's is about 160km away.... Will pick them up when i'll be around the area ! Thanks all !
  19. The postage would be horribly expensive Can you guys give me the models of tyres , the only one's they have here are Holeshots.
  20. Came late from work today so didn't have time to take a look at it , will update with feedback as soon as i get something going Thanks to all that helped !
  21. I will have a look tomorrow when I come back from work Thanks guys !
  22. I'm looking for ideas on how to fix it ;/. Do you guys have any other ideas?
  23. I can feel the clutch being lined up correctly , there is very minimal travel until clutch is begining to engage and vice versa. I read in the internet about 3 cables going into the clutch lever , I will check if I have them all. Topic : http://forums.everything2stroke.com/archive/index.php/t-19283.html
  24. I did about 15 Hours on it after I bought it.
