amont21987
Everything posted by amont21987
  1. this may be a really dumb question but if i dont gap my plugs can that make my quad miss out at high rpms?
  2. well thats what everyone has told me but i dont see how my first set of carbs did it then the second set that were new did the same thing as soon as i put them on. it doesnt even have to be started if i just turn my gas on its like its running right thru the carb and out the overflow tube
  3. I have a 01 banshee with toomey exhaust, its been bored 0.20 over and ported i have 300 mains stock pilot jets k&n airfilter. my problem is i have gas pouring out of my right side carb but i just bought these carbs because the carbs that were on it when i got it did the same thing and i never could get it to stop so i bought new ones and they are doing the exact same thing and i have no idea why they would be doing that so i was hoping someone out there may be able to give me some advice. it runs great it just leaks gas bad
  4. amont21987
    Need parts!
    I need a few little parts to get my quad riding again first I need a nut for my front hub then I need both of the front motor mount bolts because someone didn't tighten them up and they fell out of the nerve bars if yo have any of these I you would please either email me at [email protected] or text me at 3179795895 because I don't have a computer and those are the only 2 ways I can communicate until I get my computer back
  5. I'm thinking about buying the vforce3 reeds but I'm curious what the differ ce is between them and boysen power reeds besides the price
  6. amont21987
    Key assembly
    I have lost my key and need a whole new set up
  7. Hey guys I am in need of a few parts, I bought some used toomey t5 pipes and need some exhaust hangers for them I would also like to find some of the clamps for the union of pipes and silencers I also need 2 new bolts that hold the front hub on that's in the center of the tire..... Not sure what they are actually called. I want some reed spacers too if anyone has any of these let me kno. I need like all new bolts and stuff for my plastic and for the side covers on my motor
  8. I want reed spacers, pm me ur paypal info please
  9. I'll take the hangers, haven't ever bought anything from jere before tho what do I need to send u the money? I have paypal
  10. I would like the clamps if you still have them, what all have yo sold so far and where are you located. I see you said the frame was titled in Indiana which is where I'm from I also was wondering if you have the bolts to hold the exhaust up as well I have toomey as well but just rebuilt and don't have all my bolts
  11. Yes that's all I have changes recently and yea it has gotten a lot colder and it has the stock mains whatever they r
  12. I haven't jetted it for the port or the bore yet I just got it together and fired it up and took it down the driveway to see if it was running right and to make sure the tors eliminator kit was going to work right
  13. And no I haven checked for air leaks not real sure how to do it
  14. Stock carbs and jets, I hadn't gotten into that yet I didn't take them apart or anything like that
  15. Oh and I also put new boysen power reeds in too but that was before I tore it apart and had it bored and ported
  16. Ok so I rebuilt the top end on my shee, I went from stock to .20 over had it ported put an adjustable timing plate on it and advanced it 4 degrees I have toomey t5 pipes and silencers and now that I have it all back together and got it running it has no power and the power band is not kicking in and every once in a while my left side will quit firing all together. Has something similar to this happened to anyone else or does anyone else have any ideas?
  17. Yes I only did a top end and I'm only using my cell phone because I don't have the Internet and for some reason the search function isn't working.
  18. Ok so I had my banshee ported and bored at the beginning of the summer last year and it was just now put back together and for whatever reason it's not getto g fire to anything now and I'm want to know how can I test my stator to see if that's what's wrong or if I need to look somewhere else for the problem
  19. Id like the cascade clamps
  20. Do you have any carbs to sell
  21. I need the left side carb body I have one with all good parts in it I just messed up putting the tors removal kit on the left one and now the hole I drilled is to fat so I need a new body
  22. Or do I need to get a whole new carb or what
  23. So I got a tors removal kit and when I tapped the second carb and put the idler screw in it didn't go all the way in so I put the tap back in it and it was hard to turn so I redid it well now the idler screw just pushes in and pulls out without the threads can it be fixed Please help
  24. I do anodizing for a living, cast aluminum can be anodized but its impossible to anodize 2 things the same color with cast aluminum because of the inpurities.
  25. I am having my cylinders proted and bored at fast and wanted to gain some bottom end without giving up top end, if I change my sprokets for bottom end is that going to take a lot away from my top end or is their a combo that will give me more bottom without taking my top end away
