j stang
Everything posted by j stang
  1. Just seeing what's out there for sale. Kinda like to have Paul turners, but I'm looking for others also. Sent from my SM-G930R4 using Tapatalk
  2. j stang
    Gas tank
    Looking for a gas tank Sent from my SM-G930R4 using Tapatalk
  3. You still have these?
  4. Ill come find ya and shake your hand. Introduce myself.
  5. Its at the concrete rv pads down by the entrance into the dunes.
  6. We'll be there to meet everyone. Got our spots reserved.
  7. Are you running a stock stator. I have seen ricky stators that would not let the motor rev above mid rpm before. Id checks your ohms on your stator just to be safe.
  8. Sent from my SCH-R970 using Tapatalk
  9. Got my new seat in today. I must say this guy is top notch perfect. Think im gonna take the decals off to match the seat. Sent from my SCH-R970 using Tapatalk
  10. You might look on the rz 350 form for wicked motor sports he makes some really nice flanges and after market goodies for the rz 350 Sent from my SCH-R970 using Tapatalk
  11. On your swing arm its part of the nylon roller assembly.
  12. I got the same problem on a bike i just bought and its all stock except for the pistons. Im gonna do some measuring mabey tomorrow and see why its like this. the base gaskets was those cheap ones that come on ebay.
  13. You can check the ohms on the stator and see if its with in specks. Seen this problem before on a new ricky stator and tested it and it wasnt in specks, it wasnt off but by very little, so we put a oem back in to check and it ran perfect. Dont trust anything but oem stuff.
  14. Thank you
  15. Pm sent
  16. Looking to put another bike together and in need of pistons and mabey 19cc domes thanks
  17. Turn your air screws 1 and 1/2 turns out also
  18. Did you spray the filter down with oil mabey you got to much on the filter, sounds like its getting to much fuel try lowering your needles one clip see if that changes anything.
  19. Are your slide in the right carbs make sure the half moon cut out is facing towards the rear of your bike and the bowls go on one way also.
  20. Have you ever done a rz stator before?
  21. Make sure your throttle slides are in the right cards you should see a half moon in the back of the carbs if there in wrong it won't idle
  22. Do you know if your crank is welded, if it is not it might be coming apart.
  23. Are those 22 inches tire on the rear ? I like the looks of a 20in tire on the back
