Kendrick81
About Kendrick81
  • Birthday 05/05/1981
    Rapid City
Kendrick81's Achievements
  1. You guys are freaking awesome!!! Thank you so much for your help and great advice.
  2. Thanks Tricked, I'll find a welder and figure something out......any idea on how big it's supposed to be or where it should be stopped? I have actually had the steering lock out fully on me a couple years ago in the woods......really freaked me out luckily it was low speeds, and I hadn't put way more money than I should have into it like I have now. Good advice from all of you.....I really appreciate it. Anyone else willing to chime in with ideas would be greatly appreciated as well.
  3. Larry, both sides had to be adjusted, they had toe out on both after the wreck, really weird to me actually.
  4. Ok so moral of the story is cough up the dough and fix everything I can see? Ok another question........if the stopper on the frame is not wide enough to stop the steering stem and the tie rods go all the way to lockout position at full turn, how do I fix that?
  5. Hello all, I got in a wreck the other day and messed a few things up. One of them being the part of the steering stem where the tie rods attach. It looks like the left side is bent down a bit (not too terribly). I am able to align the Shee straight......can I run it like that or do I need to get another steering stem? Also the main point of my question as the topic says (should have started with this....scatter brain!) is that the limiter that is on the steering stem never touches the stopper part on the frame (sorry for not knowing the terminology properly). Honestly I don't know if it ever has (since I've owned it)! Is this a big deal or should I just align the Shee straight and let it run? Another part of the issue is that the front right spindle appears to be bent (closer to the rotor), however again I can still align the bastard straight.......should I replace or can I just run it? Any help on these issues would be great. I will try and post some pics for you to see, because I think somewhere in there on the right side I have a bent heim joint or something weird, maybe you guys can tell me since you have experience far greater than mine........the real kicker is, what if it's the left side that is bent because that's what I have to compare it too! J/K pretty sure it's the left side that's messed up. Much thanks for listening and in advance if you reply. Bob
  6. Hey thanks Nightmare, is that 22" stock or what I should have with the +2, or are they the same either way? Sorry..... don't know much about these things but I love it! Any thoughts on replacement? Is there a process to go through after I replace the cable in the front or just tighten bolts and nuts and top of the fluid and get goin?
  7. Oh wow, you don't need to go to that kind of trouble, I appreciate that.....they have a number and email I can use, but are closed now, so I was just seeing if anyone knew off the top of their head so that I can get it ordered ASAP. Thank you for your reply and so promptly.
  8. Hi all, any help would be greatly appreciated.........I had a crash a couple of days ago, and amongst the repairs I have to make is a front brake line replacement. It's the front brake cable going to the right caliper. I am using Speedlinez cable and I have no idea what length I should get. I do have +2 a-arms. I only need the one cable and am going to buy the cable from Speedlinez site, but for a single universal cable I need to know the length to buy. Does anyone know what the stock length is? And if they do will I just add two inches to that to compensate for the +2 a- arm? Thank you for looking and any help provided. Bob
  9. What do you mean old style stator?
  10. Does anyone know of any good banshee guys in Rapid City? I had a local mechanic work on my built Shee and he left it in shit condition. I have a lot of money into this thing and really don't want to have to worry about it, and currently, I am worried about it. My builder is in Vegas and its way too far to travel to have work done, so if anyone is in Rapid or knows a good guy in or around Rapid I d appreciate the knowledge. Thanks, Bob.
  11. Thanks Rider.....it is a Ricks I believe, but it has to have been bad out of the box for me to have this issue, is that possible? I get that they are shit but everyone seems to have a problem with them eventually, some quicker than others.....this stator is brand spankin new......WTF.
  12. Oh shit, that's not cool at all....mines a bit different.....I ll try and up load it somehow.
  13. Will do General........have you done anything about it so far? What's yours doing exactly?
  14. No Tricked....the parking brake and TORS were gone when I bought it.....and I have 34 mm flat sides as well.
