vbanshee
Everything posted by vbanshee
  1. two sequences first 18 ft lbs... then 20 ft lbs
  2. im also open to trades... tell me what you got!
  3. red shocks and a arms comming off a 2003 shee normal wear on them i got a new front end no need for these 100 plus the ride
  4. i had the same exact problem with my shee ... i even tested the coil and it was bad. i replaced the coil but still no spark . my stator went out as well so if your bike still doesnt start (hopefully it does) check your stator
  5. ya i think so... thanks brotha
  6. which nub is it supposed to go on? its loose and if were talking about the same little nub it seems impossible to get it off
  7. ok so my bike kicks over fine and all but the kick lever wont come back up i replaced the clutch gasket and now it wont go back up what did i do wrong?
  8. thanks brotha you sure know your banshees great help
  9. selling a bottom end for a rm250 has NEW crank NEW rod almsot new tranny almost new clutch i paid 400 dollars for this til i sold my rm it for a 92 but may fit other years.. will let go for 150 plus the ride
  10. so do you think i should just wait to put the shocks on til i get new a arms?
  11. they are works tripple rates... set up for 180 pound rider i weigh 190 pounds
  12. so i have new shocks setup for plus 2 a arms i know they fit but will it ride good til i get new a arms?
  13. they are stock cags... ill get pics up ASAP
  14. boysen reeds with cages only 1 hour of use on them. will let them go for 55 shipped
  15. payment sent to your paypal
  16. sweet thanks appreciate the help
  17. getting my motor back together... i have a cool head with the 19cc domes stock juggs. what is the torque i should use to bolt down the top end? 10lbs? i have no clue thanks guys
  18. thanks man good to know ... im happy with my investment!
  19. just bought a set of works tripple rates for my shee... are they good?
  20. check your plugs... also this happened to me before. if you have a stock head check it out see if theres coolant comming out of the head if there is your head gasket is blown . i was riding mine around ran fine once i took it to buttercup it bog no powerband it was mixing coolant with the gas and not being able to fire up the gas . so check the head
  21. i have 19cc domes on my cool head by pro design . pro design said if i run anything under 22cc domes i need to run race fuel? is this true? ive ran it off pump 91 and never had a problem
  22. so the people who built my motor put it in for no reason!? this is good to know thanks
  23. so im rebuilding my shee and there was a head gasket on there and i have a pro desgin cool head with the o rings all in there ... however ive been hearing from people that i dont need the head gasket if im using a cool head because the o rings seal it? is this right? i was even told id gain psi by not using it? is all this right have i been using a head gasket for no reason? thanks guys
  24. stock crank one rod needs bearing i can send pics thru pic messaging my computer wont let me upload it im in san diego ca. 120 plus the ride obo
