toytech
Everything posted by toytech
  1. down load a manual and do it yourself. Fast racing has a very good clutch, and the hubs and basket if you need them too. google search free banshee manual. or go to a book store and buy a clymers manual. theese things are easy to work on.
  2. green would look good
  3. uh oh mine was blown up when I built it then. still runs 2 yrs later though.
  4. very true. sometimes you have to wait to get it done right . my cyls sat at Fast Racing for 5 weeks to get ported and bored, took him 3 days when he started them. well worth the wait.
  5. he used to do that on the 250r motors to, they ran strong.
  6. does anyone have the phone number for direct drive? I need parts for my lockup cover. and thier website doesn't work.
  7. around 125
  8. a cheata cub and 4mil crank. will give you huge gain, and you can always port it later. and you start off with new cyls.
  9. I have a set of t3s they do not have any markings on them. we had them on a mild ported stock strke and they run well.
  10. I use toyota longlife coolant mixed 50/50 it dosr not have the silicates in it that eats the waterpump impeller
  11. You needed to cut them off the front end you should have taken the rivets out and taken them apart and cut the outer and inner tubed the same amount and then put them back together with new rivets
  12. I have simular motor and I run 16 f and 41 r with 21" hauler paddles at silverlake.
  13. toytech
    gasket issue
    why do you have mulyiple plates? if you use good quality gaskets it should not be a problem. you could get ahold of a shop that rebuilds air compressors they can get hard gasket material.
  14. use silicone grease on the o rings and work them around, they fit. do not cut them.
  15. popssibly an air leak, or throttle cable hung up.
  16. talk to who is doing your porting. fast racing sells new kehins for around $350 a pair . I would offer him $150 at the most
  17. our 421 with 21cc domes has 175 comp. you have low comp. you should do a leak down, sounds like an airleak on left side.
  18. had a great time over the 4th
  19. I know the tm carbs are a tight fit with the old fmf pipes. you have to angle them a little bit.
  20. if you want to go fast!!!! if not buy a 4poke. and watch us all pass you.
  21. all loaded up and ready to head to the dunes tomorrow,
  22. shorten the silencer 3 inches, it will sound better
