toytech
Everything posted by toytech
  1. copper coat spray will work great, but use a new gasket and install the way tricked just explained, and check the surfaces to make sure they are flat.
  2. check for spark, then check your float level again.
  3. just have someone machine a stock head to accept coolhead domes. but why do you want to hide that you have interchangable domes.
  4. low compression, to much gear, jetted wrong.
  5. thats funny shit rite there.
  6. it will change some but not drastic. proly time for new topend
  7. take your waverunners to the dunes and drag race at the flats. perfect conditions. mothers day week end there was 3ft of water there
  8. do a search and see how to do a leakdown test. you can make the tester your self
  9. racetech or oem stator. racetech is a sponsor on here and his stators have tested out great by members.
  10. 65mm bore and a 4mil crank make around 397cc.
  11. do you still have the parking brake switch still hooked up?
  12. welcome to bhq!! now a few are going to bitch because you posted this in riding events, newbie mistake. take messurements off a strait frame and see if it's bent. if you need a arms I have a set for sale $100 plus shipping.
  13. maybe the powerband broke, try a new one.
  14. put the original stator back in the fix the air leak.
  15. I thought puple powerbands were the best?
  16. looks good. I too like to paint my frames that way you can do touch up or ad things or cut them off and not have to redo the whole frame over again. mine is 2 years on the paint and still looks great. powdercoat is over rated.
  17. the inner clutch hub and the pressure plate have to be lined up correctly to engauge look in the manual it will show you.
  18. take the ends off the coil wires and check for corosion, the 90deg ends and corosion are the 2 biggest failures of a coil on banshee's.
  19. check at autozone, the lower pressure, caps of from toyota's will work. take it in and match it up.
  20. did you unplug the tors box up by the left front of the gas tank?
  21. x2 -2 swing arm, elka shocks, +4 axle, +2 +1 front a arms. 20inche razr tires, K and N filter with no box lid, v4 reeds. hjr does an awsome mx port.
  22. I guess my bad, don't call stellar and give him (a site sponsor) any bussiness. I just thought he proly already knows what balljoints they are because he's proly done studies on other arms to make improvements and build a better product. Matt, why should anybody ever call you then for shock service since you don't manufacture your own shocks? just sayin why not send a site sponsor the bussiness? most are willing to help when ever they can.
  23. could be be old style vito's fat bastards
  24. we'll have pics and possibly a vid of the hill climb, this week end.
