n2otoofast4u
    224
Everything posted by n2otoofast4u
  1. If you are asking about fuel pumps......... you don’t need a fuel pump.
  2. I have seen with my own eyes a stock stroke DM on stock cases. If you have DEEP pockets, the possibilities are endless.
  3. Cameron has REALLY weird sexual tendencies, but he knows what he’s doing! Talk to his wife, she’s way cooler than he is!
  4. 1- you’re from MI, I don’t expect you to be smart. 2- you’ve got a hot ol lady, so I’ll make a partial exception for #1 3- if it’s a play bike, it’s just that. Run it on pump, run the hell out of it, PLAY with it, and enjoy it on the cheap and easy. Sometimes, less is more.
  5. Pump gas or Methanol. No need for anything else.
  6. If Zilla would have finished his EFI setup, he’d be rich, and I’d have another turbo bangshee.
  7. What happened the the magical "self tuning carbs"?? I remember someone on here actually got a set.
  8. If it runs good, then run it! Don’t fix something that isn’t broke! Buy your own tester! $30 or $300. Just buy one. Use it, and your procedure as a baseline. But, until it gives signs of slowing, run da fuck outta it, that’s what they are made to do. Good gas, good oil, good warm up. Run it!
  9. Matoon machine on EBay. Only one to buy!
  10. You’re focked. Buy a titled frame and start swapping.
  11. Where are you from?
  12. I’m not doubting.... See you in 9 days.
  13. Thanks for the deal bud! See you in a couple weeks! N2O back in da game!
  14. What is the application? Drag, trail, etc. On a drag bike, its virtually inevitable that you will be wrenching on it, so ATF has always been my go to because its cheap and works fine. If its a daily rider, duner, trail type deal where you just want to add gas and ride, then I would recommend a Redline, or something along those lines.
  15. If you cannot afford a Timesert, then you should not own a banshee.
  16. I think I’d figure out why it’s blowing the gasket first. If running correctly, and tightened correctly, they RARELY go bad.
  17. Take them off, install stock carbs, ride. You have no reason to run those carbs.
  18. Didn’t Dicklez, or Gun For Children work there? Sent from my iPhone using Tapatalk
  19. Carb bowls on correct side Choke tube on Carbs clean Jets correct size and clear Carbs synchronization is correct If one hole goes dead, I’d place bets on carbs. Do a real compression check so (1) you know it’s good, and (2) so you have a baseline that you can refer to as things wear out.
  20. Stock carbs, K&N’s, TORS Delete, Jet correctly, done.
  21. Don’t be a dick, dick!
  22. Most productive thread on this site in a long time!
  23. Expensive timing curve!
