Alex29573
Everything posted by Alex29573
  1. cutting the springs works very good. just dont cut too much off
  2. so i guess its safe to say that the way that guy did it is wrong because of the shock angle.. In order for it to work i would have to get a no link swingarm which flips the mounts downwards like this one - http://bansheehq.com/forums/index.php?showtopic=126622 thanks everyone!!!
  3. in a way i think I already messed with the geometry by putting a lowering block in there
  4. I really hate the rear dog bone with the drop block set up i have and want to change it up. Can someone tell me if there is anything bad about doing this? My question is if i have to have a special swingarm made in order to mount a direct shock Or Do i just measure the distance from screw to screw and get a shock that is that length? I would need a 12 inch shock in this case.
  5. Rear wheel spacers sold locally. The only thing i have left is the SHIFT PRO KIT. 45.00 takes it
  6. Front wheel spacers are sold and shipped!!
  7. sick.... did someone in miami do the polishing??
  8. New prices Front aluminum wheel spacers - 1 3/16 inch each side - 40 shipped Rear steel spacers - 2.5 inch each side - 18 shipped Shift pro kit - 45 shipped Modded shift star - 14 shipped
  9. buttery smooth shifting up for grabs!!!!!!!1
  10. the shift star was modded by a local shop here in miami. This is a real nice setup. it actually shifts so easy and soft that i now have to get rid of it because i have an override. With the override it now shifts gears by itself with the motor vibration or on a bumpy road...
  11. http://i61.photobucket.com/albums/h62/alex29573/SN855820.jpg http://i61.photobucket.com/albums/h62/alex29573/SN855822.jpg http://i61.photobucket.com/albums/h62/alex29573/SN855823.jpg
  12. Front aluminum wheel spacers - 1 3/16 inch each side - 45 shipped Rear steel spacers - 2.5 inch each side - 20 shipped Shift pro kit - 50 shipped Modded shift star - 16 shipped PM me for pics
  13. Hey, is that a stock stroke cub? is it ported? Whats overrev? I've heard of it but never understood what it means...
  14. no one has ever set float heights on pwk's?
  15. which race gas? what timing advance?
  16. when i measure the 16mm on my PWK carb, it says to measure from the gasket sealing surface to the bottom of the float. which lines show where the 16mm should be at? thanks
  17. macdizzy.com
  18. these are different too, the skirts are kinda pushed in
  19. whats up with the wiseco piston 842M06400 for a banshee? Wiseco doesnt show a picture but do you guys know if they look like this?
  20. can you run a pump fed carb by gravity?? i understand you probably cant run a gravity fed carb with a pump because that type of carb is not set up for any pressure. but how about vice versa?
  21. I only got one and it has the hole for crossover tube 25.00 shipped send email address for pics
