VegasJeff
    7
Everything posted by VegasJeff
  1. great guy to do business with
  2. I ran the trinity shift drum for a few years and it was a considerable difference in shifting.It was a little priceyand I could of saved cash by sending it somewhere for the mod,but one stop shop was my decision. I just sold two of them last week. Jeff
  3. x2 on that. I ran them for a year with the FMF's and no lid on the box.It wasn't a white knuckle ride,but just a little better.
  4. thank you sir!
  5. just wondering if anybody could give me the low down on how to lap a flywheel.I checked the search function with no success.I think AK heaten explained it once on here. thanks in advance. Jeff.
  6. I have a nice set of stock intake boots. let me know if you still need them.
  7. PM sent
  8. PM sent
  9. If they are the stock phillip bolts,your gonna have to take the mag off.
  10. would you want to trade for a stock 87 fourtrax?
  11. time to upgrade!sounds like the rivets that hold the gear on are getting worn out or the cushions are shot.
  12. You have to remove the magneto and loosen up the bolts that hold the plate. You will see on the right side of the plate where the -/+ numbers are engraved,the center line between -/+ is stock setting.where the cases mate together is where you set the mark at,so if you turn the plate to the right to where the +5 line matches to the line where the cases mate your good to go. hope that makes sense to ya? jeff..
  13. hey blanco,look for a yellow banshee and an orage one with drag pipes and +6 swingers.would like to see your ride.
  14. hey old roost! If the knob wont stay out then the choke isn't being applied. try starting when you hold the knob outmanually and see if it fires up. Jeff
  15. I just had a rotor custom made by JD's cuatoms and I have to say it's the coolest thing Iv'e ever purchased.
  16. Is the parking brake on?
  17. x2 cel,s
  18. check for air leaks.
  19. cascade sells the billit insert.dont make the mistake i did by spraying carb cleaner on it.the wholething just shaterred right in front of me.
  20. Excellent sellar! Had my part in no time flat.
  21. Thanx Cody! anytime you need something just give me a call. Jeff..
  22. x2 Chris is a great guy to do business with.
  23. BUMP for a nice fuel tank.
  24. I had to grind the box end of a 12mm wrench just to make it fit. It is basically torqued to "two grunts" with a long box end, hahaha.
  25. Head nuts (sequenced)= 20 ft-lb Cylinder base nuts= 20 ft-lb If you have a cub cylinder, the base nut torque is two grunts.
