bassmaster345
Everything posted by bassmaster345
  1. Here is some pics, I will sell it for $500 shipped. If paying by paypal add the 3% fee.
  2. I have a complete banshee bottom end I am looking to sell. I replaced the crank with a brand new hot rods stock stroke crank, clutch is like new, trans is in great shape, every bearing and oil seal was replaced in the motor before putting back together. Motor was running good then I pulled the top end to get the cylinders ported and sold the bike so this is what is left. Motor has around two hours of run time since rebuild. I would rather not ship so anyone around Wichita,KS Interested? I would like to get $500 for it.
  3. http://motors.shop.e...&_ipg=50&_sop=1
  4. bode1 good buyer, fast payment, good comunication. Glad to do buisness with. Thanks again and enjoy!
  5. You got PM. Thanks
  6. I have a brand new still in sealed box Mr. Gasket thermocap- $30 shipped in the U.S. brand new sync tool $35 shipped in the U.S. A set of rear hubs 4x115 in good shape w/o nuts $35.00 shipped in the U.S.
  7. I used a sawzall to cut mine off, going between the frame and swingarm. Just make sure you put something in front of the engine to protect it. You will end up destroying the dust caps so you better get a couple of them if you haven't already.
  8. Here is a stock head on ebay look real close and you can see the numbers stamped next to the bolt holes, just make sure after you run it a couple times you re-torque. http://cgi.ebay.com/ebaymotors/YAMAHA-BANSHEE-STOCK-HEAD_W0QQitemZ250487194051QQcmdZViewItemQQimsxZ20090824?IMSfp=TL090824169007r31894
  9. If you still have the stock head I think the sequence is stamped on it.
  10. You will know if something is wrong. More than likely you will have a hole in the top of the piston or meltdown on the sides of the piston. Is it just one cyl. without compression or both? What do the plugs look like?
  11. Welcome to the BHQ! I run 40/1 Klotz supertechniplate. If you do a search on oil you can read up on the topic as it has been gone over umpteen billion times LOL. :biggrin:
  12. Where do you go riding at Tator? Looking for some good riding spots not to far away.
  13. PT Mids or Pro Circuit
  14. how much for stator and flywheel shipped to 67217?
  15. Could be the rubber plug in the bottom of the cylinder leaking.
  16. What year stator you got to get rid of and is it in good shape?
  17. Carbs and Intake Sold pending payment.
  18. I don't have a throttle cable for them but the one you have should work you can look here for reference- http://www.motionpro.com/motorcycle/search...t_Throttle_Kit/
  19. I have a brand new set of PWK 28mm carbs for sale never mounted- $250.00 shipped in the U.S. I also have a brand new never mounted Chariot billet intake with built in crossover $150.00 shipped in the U.S.
  20. Give Jeff at F.A.S.T. a call he is just a couple hours away. http://www.farmandsandtoys.com/
