Tator
About Tator
  • Birthday 09/30/1986
Contact Methods
    Wellington, KS
  • Interests
    The dunes, My mudd truck 86 f250 dana 44 front 60 rear, 33" boggers, my buggy, and quad, huntin and fishing ya i'm a busy man
    92 banshee cool head big single carb fmf pipes white and teal
Tator's Achievements
  1. loud pipes save lives, and get you tickets wich reminds me i need to find a cheep mufler for my cummins to pass a test so i dont have to pay the ticket
  2. yep they like the gas, i have a 2 into one also but its nothing for me to go threw 15-20 gal for a weekend trip to the dunes and thats stopping at the top of ever 3 hills to wait on the raptors
  3. if you use a .035 or smaller fluxcore you can weld it with that, thats what i use on everything, i have welded some realy thin stuff with it like re welding a cannopy frame you just have to know how to work it and you will probly have to spot weld it, i have welded on all sorts of auto body, and exhaust with mine. you just got to know when to roll em, know when to fold em and know when to walk away befor stuff starts flying across the room
  4. I have a couple cracks in mine too im about to weld up, i have a small mig but will use the torch, i can make that look just like a tig
  5. I go down to waynoka alot, or down to south haven to Stricklands at the Kansas Bad lands its not real great riding out their but its 10 bucks for the week and its 20 min from my house. I just picked up a +4 swinger off craigslist going to pick it up tonight after wrk. I also have 40 acres out here i mess around on a little
  6. Hey yall im working on my first rebuild, the bike will be .30 over when done thinking about a light dune port, my bike has the trinity 2 in 1 carb that i love but was wondering what the best pipes to put on would be it has fmf sst on it now but the head pipes are craking, I am doing shift mods modded star new lever and springs due to worn out adjustment and spring. also looking into RS for timing and to power better lights. i ride alot of trails and a little open dunes. thanks for all the help
  7. well i split the case today, all the gears look good, I found one of the shift forks that had verry little wear on it, so i'm going to replace it, but on the shift rod the big spring looks to be worn and the adjustment screw that the spring rides on is worn to about 1/2 the diamater of the screw. I dont know if that would cause my problems with seccond gear or not but thats the only thing i could find that was showing wear. I will do a better check tomarro i forgot my calipers at work. the problem i had was only in seccond gear it would jump teeth but it wasnt the chain. it only did it under hard throttle
  8. Ya i knew about all the required stuff, Also planned on a Ricky Stator with adjustable timming plate, thought about turboing the crank also if i dont spend the 600 on a 4 mil. this is my first 2 stroke rebuild, but i have a cusion that use to race banshee's he said he would give me a hand, thanks for the info.
  9. Well I got my shee paid off, now puting money towrds a rebuild, well i have to last time I was on the sand i lost 2nd gear, thought no big deal time for a top end rebuild. pulled the head, one of my pistons had a busted skirt. I'm takeing my Cylenders into work tomarro to put them on a high tech measureing device to see how far out of round it is, hope i can get it out with a 20 over bore mesured the pistons and it was already 20 over so i will be 40 over, was thinking about a 4 mm crank, i'm gunna replace the crank berings while i have it apart. but what other mods should i make to my trans. I found the gears i think i need for 20 to 30 bucks a pice dont have motor torn all the way down yet so i'm going on a guess that i need 2nd gear and 2nd wheel. planned on a modded shift star. I was also wonder about how much it would cost to bore the cylenders. I was thinking about making a torqe plate and doing it myselfe I have a brideprot at my shed and a boring bar just no torqe plate cant be to hard to make. Thanks
  10. Well I got my shee paid off, now puting money towrds a rebuild, well i have to last time I was on the sand i lost 2nd gear, thought no big deal time for a top end rebuild. pulled the head, one of my pistons had a busted skirt. I'm takeing my Cylenders into work tomarro to put them on a high tech measureing device to see how far out of round it is, hope i can get it out with a 20 over bore mesured the pistons and it was already 20 over so i will be 40 over, was thinking about a 4 mm crank, i'm gunna replace the crank berings while i have it apart. but what other mods should i make to my trans. I found the gears i think i need for 20 to 30 bucks a pice dont have motor torn all the way down yet so i'm going on a guess that i need 2nd gear and 2nd wheel. planned on a modded shift star. I was also wonder about how much it would cost to bore the cylenders. I was thinking about making a torqe plate and doing it myselfe I have a brideprot at my shed and a boring bar just no torqe plate cant be to hard to make. Thanks sorry i posted in the wrong section was looking in 2 sections at once
  11. Well i tore the top end down today, think i found out why it was running shitty, besides 2nd gear the piston on the stator side was busted, and cracked, the bore dosnt look to bad hope .010 more of a bore will get me, well thats all the findings for now , only have the top end apart at the time, going to split the case tomarro first timmer any tips would be appricated thanks
  12. well i know its been a while but i finaly got the paddles off and the knobies back on, rode it found out it only dose it in seccond so i guess i get to do a tear down, o well it was about time for a top end rebuild anyway, trying to save the money for the 4mil crank, got some new neibors with yfz's and i still smoked them without a good seccond gear hehe f##king 4 strokes
  13. sprokets are band new just put them on befor trip, new chain to come befor next trip its geting some wear on it, havent had much time to work on it been working 12's all week grrr that realy cuts into my mess around time, but lake season is comeing hope to have better luck with the boats :biggrin: hope to get some work done on the bansh this weekend thanks for the idies TATOR
  14. Hey yall I was down at Waynoka this past weekend had a good time but have a problem, when i was riding in the trails it would feel and sound like the chain is jumping teath so i checked tension it was a little loose but not bad so i snuged it up a little bit but still had the problem, it only dose it when in loose sand and you get on it like going around the turns if i'm out on the flats and dont have much load on it its fine, I'm thinking its something in the trans but i'm not real shure, realy wasn't wanting to tear down the motor but i guess i will, but as the saying gose your not having fun enless your breaking something . well any input would be helpfull, thinking 4mill crank when i tear it down more power to kill myself
  15. Tator
    waynoka time
    sounds like a good turnout, i will be down by shelter house 1 and 2 in april dont know where at in march but their will be a big group of buggies in april we get shelter 1 and some buddies get 2 its hella fun
