88-04banshee
Everything posted by 88-04banshee
  1. Yea because i found them for $125 haha i honestly didn't care if they were o7'-08's when i was searching i was happy finding a set to swap out,the stock suspension was horrible and doing this i really enjoy riding more because the way it handles-i can hit the whoops in 5th gear now and it soaks them up with ease (still need to do something with the rear) good luck and keep us posted,
  2. I just found a picture i took installing the yfz spindle's from the stock banshee ones on my arm conversion-can you tell what side has all yfz parts ? haha
  3. Score-that is a smoking deal so far. i started my conversion using the banshee spindles and wasn't happy with the travel so picked up a set of spindles/rotors/hubs from a yfz and was much happier gained 3-4 more inches of travel (over 11" total now)and just rides better. i ended up using tierods from nossmachine. think they were in the $30 range and he makes them specifically for the swap. http://www.nossmachine.com/yamaha_atv_parts.htm
  4. I have been running a set of '08 ltr shocks (08 are valved slightly different)for a while with my conversion and i am extremely happy. they are a little tricky to get in there and do require some grinding on top mount of frame and some spacing on the bottom but over all well worth it imo.here is a couple pictures of mine.
  5. P.m. with addy sent, Thanks
  6. Sale pending payment.
  7. I have my stock front spindle,hub,rotor,pads and calipers with all the brake lines for sale. asking $75 shipped in the us Thanks
  8. Shipping will be about $25 but i will let you have them for $60 shipped. Thanks
  9. I have a almost new set of gbc 21x7x10 shark fin front tires. they have about 3-4 trips on them and are in excellent condition with nipples still on them. $40 plus shipping or can be picked up in San Diego.
  10. Sorry but would like to sell in states. Thanks Got it and replied. Thanks
  11. Also come with a set of stock yfz tierods.
  12. This is about the best picture my camera will take, they all are about the same it's just the top 3-4 threads on all four but from the center of hole for the cotter pin down they all appear to be good. Thanks
  13. No pm received ? ttt still available
  14. I have a set of yfz450 arms in good condition with only i small dent on bottom of one. the ball joints feel good along with all the threads. $130 plus shipping
  15. I have an extra set of arms from a raptor 700-these are the same as the yfz450 arms. the ball joints feel good however the threads are a little beat up from the original owner hitting the nut to get them off the spindles so it kind of chewed up the threads but should be able to be re-threaded and used, there is also a couple good dents on the bottom (bottom painted black)side but are not bent and usable. condition reflects the price and buyer needs to know these will be usable with a little work. $80 plus shipping
  16. When i first did the swap i used the yfz arms,tierods and shocks with banshee spindles and it worked good but sat almost 2 inches lower than stock and the tierods only had about 4-5 threads holding them to the ball joints so i broke down and bought a set of longer ones. and now have yfz spindles,hubs,rotors,calipers and ltr450 shocks. good luck
  17. Here is a picture i took during my yfz spindle swap. you can tell the side i changed from the extra 3 inches of travel, my personal opinion (whatever that's worth lol) is to run the yfz spindles with no more than a 17 1/2" shock and i think the r is about 18 1/4" but there are some that have and i would like to know how it works. like this thread http://www.bansheehq.com/forums/index.php?showtopic=112511 good luck
  18. Yes you can use the stock yfz tie rods with the banshee spindles (04-05 same size ball joints) which is exactly how i ran mine at first but the yfz tie rods only give you about 4-5 threads and i wasn't comfortable with that so i bought a set of the right length noss tie rods. then i really wanted my height back so i upgraded to the yfz spindles as well which gives you about 3 more inches of travel and allows you to run a longer shock and lifts the front a bit. good luck
  19. Negative, but if you shop around you can find a deal on a set then sell your stock ones to make up some of the difference.
