qcklys
qcklys's Achievements
  1. Any idea, anyone?
  2. Okay here's my problem, my shee has been sitting outside since like 2.5-3 month waiting for suspension parts , now that i installed everything back i thought it was a good time to change jet (since its now cold out here maybe -10 degree celsius) so i changed my jet and notice the carb were way out of sync, so while im at it I synced the carb, dont have the tool so i go by the mark and by touch for the slide, now everything looks okay, slide move at the exact same time, ping mark is right in the window where it should be at full open throttle. So i tried to start it, it start first kick and seem to go just fine but it will not keep his idle as soon as i release the throttle it die, i went for short ride and still doing the samething as soon as i release throttle it would die, i tried adjusting the idle screw on the side (Since i have no tors box anymore) and it seems its not doing anything now, i thought maybe it was because the gaz was old and there wasnt that much left so my next step is to go get some new gaz and try it out but i was wondering if any of you have an idea of what it could be (havent tried with new gaz yet will go get some today or tomorrow) but ill take any suggestion, maybe i did something wrong while syncing the carb or Idk! thanks for suggestion!
  3. After i removed mine a couple of time i put it back in and when i was kicking it it would kick free until finally sometime it grab, i looked at it and where the spring is around the gear seem loose so i remove it from the gear and put it into a vise so it could be a little bit more tight on the gear and put it back in and everything is alright since then, hope that help
  4. Okay i have to change my a-arms in front and my complete tie rod assembly so i was wondering if i should go wider? I do some trail riding, sandpit and mx track riding, so what would be the best for me? stay stock or go wider? and if i do , do i need to replace the shock?! i dont have much money so i was thinking about 500$ max for the front end, so what you guys think i should go with?! thanks!
  5. qcklys
    Suspension
    I got stadium suspension and they are great i really like them, but i didnt have to pay for them since it came with the bike hehe
  6. maybe there is a leak with the compression gauge?
  7. remove the broken tap with an extractor or something and redo it, dont waste your money on new carb
  8. Yeah i guess it's the only way to do it , thats what i thought
  9. Try with a small magnet , if its welded it will come out with the rod, well, it work for mine
  10. Hey my friend have a banshee and while rebuilding the motor he strip one of his cylinder head stud into his cylinder, he said he try to make new thread and it doesnt work , any idea on how to make new thread to put a new stud back in the cylinder?
  11. Lighting system is separate from ignition system, there is different coil on your stator for your lighting system and for your ignition system, but there is a ground that goes bolt right under your voltage regulator it is one of the 2 ground of the bike so you might bolt it just for sure if its not , other than that if your lucky enough to try a cdi from a friend who got one that would save you money and time hehe
  12. Im from Quebec, southshore of montreal! You guys from ontario and quebec we should definitely go ride anytime soon!!!
  13. Dans quel bout Ste-ephreme???!
  14. when you talk about the charging coil u mean the stator? if its way out of spec that is your problem, its hard to say the voltage goin to the coil since it will depend on the rpm of your motor, you better just test the resistance of all your component, see if your coil is well grounded to the tab where it mount, 5.89 foir the secondary seem right in spec just make sure with your manual, see if there is continuity between the ground and the negative side of your coil, you should not see any resistance maybe 0.02 or something like this. this mean your ground is good, might as well see the resistance of your spark plug cap and maybe cut like 1/2 an inch of the wire so the spark plug cap is really touching the metal wire inside. check your gap on your pickup coil it should be about a business card thick between the 2 notch and the pick up.
