Okay, I have double checked all the grounds, pulled the flywheel and cleaned the poles, adjusted the pick-up coil gap. So now I am left with the CDI, but before I do that I want to make sure that the lighting system is seperate from the ignition system because someone has removed the voltage regulator (there is a long story behind this thing). There is power going to the coil, so I am assuming that regulator has nothing to do with the ignition.....?
