i dident post this so you can just look at some frames if you would like to get a frame pc's for under 75$ with a arms and a swinger than this would be the place to get it done is all
well if anyone is looking to get frame pc'd in ontario canada this is the place to get it done
i worked here for 3 years and know the quaility that this company does
http://www.selectfinishing.ca/
i will have some more pictures later on my home computer of my frame and other frames that iv done through this shop!
does anyone here scale the quad before the go out on the ice i know when i switching form a clay to lime stone i scale my quad and re set my sway bar to have more or less bite to my right rear wheel
my quads set very stiff with about 3 1/4" of travle and 5 1/4 in the front
iv never raced my banshee on ice or ridin it if that
but i wonder if getting your hands on a set of scales would help you understand witch way your setup is going when your tunnning it
there priced a little high in cananda but im sure you could find them cheaper in the states
http://www.ebay.com/itm/Proform-67650-Race-Car-Computer-Scale-Scales-System-/190718683675?hash=item2c67b82a1b&item=190718683675&pt=Motors_Automotive_Tools&vxp=mtr
now i just use my buddys and if you know anyone racing dirt track cars they usually have some or a local shop might have a set
r.r.l yeah you have a good memorey
they are sb sheares with custom silencers to match the sub frame mod
its a stock swing arm i just cut it removed about 1 3/4' and re welded it
if i back the carrier off to shorten the cain the tires hit the nerfs with 18.5' but what a diffence in handling with the shortened swing arm
the google map link is wrong here is where the track is
Quinte Exhibition & Raceway, 246 Bridge Street West, Belleville, ON
if you type this into the maps search the track will come up as A
ok guys belleville 1/2 mile is coming up soon august 11 saterday night
http://www.canmocycle.ca/content_frameset.cfm?pagechooser=cma_events_calendar
https://maps.google.ca/maps?hl=en&q=belleville+horse+track&ie=UTF-8
so far we have 8 riders ready to tear it up
2 ltrs
3 banshees
2 ktms
and a kawi
come out and have a great time i will post some videos from last years runner up jeff chandler great helmet cam view
i know iv talked to 2 guys already on the site adam i hope to see you there you two jans
as for purse money you will be getting your entry fee back no matter what place you come in
you will need a couple things befor you can go on the track
a snell 2010 approved helmet
nerf bars
thether kill switch
and rear flat track tires NO NOBBIES unless there on the front rims
if ANYONE WOULD LIKE MORE DETAILS SEND ME A MESSAGE
well i should throw my 2 sents in
iv been racing the cma for 7 years now
i run a 10 mill cub built by dan hall at a&s racing iv been blowing big 4 stroke out of the park with my set up on the big half mile track ( lime stone)
i also raced at welland county motorcycle club 1/8 mile clay NO BANKING
i bought a dyna box ignition system and had dan program to iginton peakes one for the top horse power 111.5 hp to the rear axle ( dan uses a single wheele banshee frame for a motorcycle dyno
the 10 mill made 64.8 tq and 111.5 at 9800 rpm
so when i go to the small track the igintion is switched to the lower horese power rating for roughly 80 - 85 horse and let me tell you the is no power band at all
i can roll the throttle just like the 4 stroke to make it hook up iv talked to many top riders in the cma
they all say as soon as you hit 90 hp your making to much power and its hard to make it hook up
i havent raced a high banked oval (clay) but as anyone else that has raced they will tell you setup and tunning will give you the best answer
so basicly what im trying to say go out and race and find out what you need you wont get a perfect setup on banshee hq for reading fourms it will point you in the right direction BUT you wont find out till you hit the track
a stock stroke and bore with a set of pipes wont get you the finish line first against a couple of buit 450's
i had the same problem with my banshee it wouldent idle i just adjusted the nuts on the top of the carb caps
what size pilot jets are you running have you tryed playing with the air screws ? i set my air screws at 1 1/4 turns out
your banshee pulles up to 12070 rpm's. are you talking about peak horse power, or max rpm?
i found when racing large tracks if you gear your banshee to hit your peak horse power on every straight away its a lethal combination
