vulvafan537240
    15
Everything posted by vulvafan537240
  1. Chariot is a 1 piece
  2. must be a iphone thing. full site works fine on my android.
  3. Did you even read the jetting info I posted? Honestly you may be better off taking it to a mechanic.
  4. http://www.dfn.com/agservices/jetfaq.html
  5. Gotta take the plugs out...
  6. It will be lean with stock jetting and aftermarket pipes. Also, look at the plugs and tell us what they look like.
  7. does it have aftermarket exhaust? what size main jet are you running? what do the spark plugs look like (black and wet, grey etc)?
  8. how did you break this motor in?
  9. ive never used tapatalk. i dont even use the mobile site. i always use the full site on my phone.
  10. Hmmmm.........
  11. depends on the portwork. if you get it drag ported now, you probably wont be able to have it re-ported for the 4mill. as far as clutches i have seen all of these be recommended on here: FAST driveline pro lock tusk etc.
  12. Trail riding with a cub isn't advised no matter which pipe you run
  13. compression is A factor but its not the ONLY factor
  14. the bump in compression will give you a little more bottom end power
  15. I love those end caps. I like the colors too. Usually not much of a fan of blue plastics, but I like this one with the black frame.
  16. Totally worth it. There's a reason those tires are bald as hell.
  17. you'd be typing in all caps and using lots of exclamation points if you had pms
  18. Why does my blood look like piss?
  19. I think it was on myth busters or something. Matt is the fart expert.... or shart expert I should say.
  20. High humidity makes it stay low and linger. Fact.
  21. Over under for sure
  22. I'm confused. Why run alky if you can use race gas with your compression with no deto?
