orion6781
orion6781's Achievements
  1. Yeah i went in there one time to buy a 250 for my wife and they would only give me sticker price. BLAAAAAHHHHHHH. So while i was talk ing to the salesperson, (always looking for the banshee). I asked them if they carried any Klotz oils. the guy said he had never heard of it. so my decision was pretty much made there. they do not want to negotiate and they do not know too much about motorcycles if they only heard about things in their shop. What i got out of it was there way was the right way, and everyhting else was wrong. BLAHHHHHHHHHH SCREW' Em. C&S and Eastside Cycle is pretty good. at least customer service wise.
  2. The Raptor is faster stock just by a hair. when it os that close it comes down to the rider. so you could've beaten a stock Raptor, not because your bike was faster but because you were a better rider.
  3. Choke tube connected???
  4. Change the plugs around and see if the left runs still or its the right. if thats the case change your plugs, if not fixed maybe bad plug wire.
  5. once it gets close to 100 its a good sign to rebuild. get some port work while you are in there!!!!
  6. .085 is alot to be shaved the only way i can see it making it run cooler is because you would have to run race gas anbd that burns at a lower temp.
  7. If you know that you are not going to use your airbox anymore then you can just cut down the airbox to where it is just a holder for the overflow bottle. and its free.
  8. Just moved down here and i dont know where to ride. I see alot of mountains but, I dont see anyone riding. I am near D-M AFB, and the first weekend i would be able to ride is the 5th and 6th of June. So anyone that can help me out, or point me in somekind of direction, I would greatly appreciate it. I do not want to be camping out either, so I am hopping there is something here within a 2 hour ride. Thanks in advance.
  9. they only put anti icing in av gas durring winter time. the gas in an airplane passes the oil which cools the oil and heats the gas.
  10. You have the silencers on the right sides? i know one of mine is bigger than the other.
  11. You can get the 33 or 35 carb, but do not expect an increase in power. The stock pipes will restrict you.
  12. I believe www.yfzcentral.com would be able to help you out. good luck!!!
  13. orion6781
    Carbs
    They have cables or not? you have pics? they are in running order correct?
  14. Did you try adjusting the idle?
  15. orion6781
    Carbs
    Looking for a set of aftermarket carbs. do not want to spend too much. Basically seeing if anyone has anything laying around they keep tripping on. Thanks
