hylander88
Everything posted by hylander88
  1. it could be one of two thing and may fix both at one time...carb's aren't in sync. or might not be enough spark check the gap on the stator..
  2. It was a judgement call. bottom arm dug into dirt, kill switch shut the motor down.........Update Bone's are all healed bike all fixed.........
  3. how's the spark????????weak spark will cause hard starting check the gap on the pick-up might want to re-gap it and try from there
  4. did you even check the gap on the pick-up coil...........I had the same problem with mine and thats all what it was........
  5. also might look for air leaks O-ring on the choke could be warn out.........and they are metric or just replace the whole choke for about 25 bucks......
  6. clean all that rust out re-gap the pick-up coil ........all that rust is going to give you a weak spark...
  7. that is a j-arm bike with after market arms...........and I think it is made up there by jenson motor sport......but need a closer look just at the arms its self...
  8. he has d-arms on top which are aftermarket upgrade for the j-arms..........and the bottoms can be replaced with newer one's I ran a check on the bottoms and they where the same part #'s...
  9. might want to check for air leak too.....O-ring in choke could be warn out and causing too much air...and they are metric O-ring too if it needs to be replaced.....
  10. adjust the gap on the pick-up coil on the stator.....
  11. adjust the gap on the pick-up coil on the stator.....
  12. check for air leak on choke O-ring might be worn..........
  13. I would check spark...the gap on the stator pick-up...first . Not enough spark would be one reason for hard to start. and how is you compression
  14. if you have any plugs in the tire already recheck them for leaks...
  15. point taken I would use a multimeter over a car battery you could fry more thing than just wire like the cdi or stator......with that 12 volt battery i think street bikes run only a 6 volt...
  16. just depends on how much and what kind you want........seen some new ones on E-Bay for under $70 bucks.....
  17. E-bays also has them cheaper on new ones too under $70.......just depends what you want
  18. yes they will, also when i was checking at our bike shop on a-arms to j-arms the bottoms where the same part #'s.
  19. NO............some spindles are different on newer bikes for the front brake caliper....but if you are just taking every thing off the j frame and putting it on an a- frame it should work...remember all wire harnest are different. for the different year CDI's and starors plugs same goes for head lights....
  20. as far on the RS topic I heard a lot of bad things with there 200 watt stators, but i have there 100 watt with no problems and had it for a year now and I'm running stock lights with it...
  21. Look on some old post in here for the down load manual the were some posted....
  22. Motorsport.com catalog does sell a replacement boot you might want to check in there....
  23. check the stator for damage if you use the wrong flywheel puller you could have done that...
  24. try hammer and a center punch to start it.........
  25. The popping sounds to me you might have the carbs. out of sink....the water problem could be a head gasket and will also give you the popping might want to do a pressure test...
