lowbuckracing
Everything posted by lowbuckracing
  1. By lowbuckracing, shot with Canon EOS DIGITAL REBEL XT at 2009-06-02 Need to get this stuff sold.. All prices are shipped,Paypal fees apply..3%,money orders welcome 1.Hot rod 4 mill crank,brand new,115 rod $350 shipped By lowbuckracing, shot with Canon EOS DIGITAL REBEL XT at 2009-06-02 2.Boondockers kit,needs platic line replaced $250 By lowbuckracing, shot with Canon EOS DIGITAL REBEL XT at 2009-06-02 3.Brand new OEM cases,no numbers,port matched for stock cylinders $300 By lowbuckracing, shot with Canon EOS DIGITAL REBEL XT at 2009-06-02 4.Vitos coolhead with 19cc domes,for stock cylinder,Stud kit and hardwear.50 vitos pistons&rings,wedge design for 2mm port change.only for stocker setup $150 5.DG Nerf Bars with hardwear..$120 6.35mm Mikunni Carbs setup for Alky,115 dumps and mains $240 7.38mm tapperd Keihin setup for alky,welded bowls $150..Not the greatest looking carbs 8.35mm keihin carbs polished,alky setup $220 9.Stock carbs setup for 4 mill gas motor $50 10.chrome rear brake lever $35 11.stock cages with after market reeds,not sure what kind $35 12.Lowbuck style air box elimanator with 2 K@N filters and outerwears for stock carb$75 13.sparkys for t-5s,.Cobra Spark arrestors,clip style.$75 14.good tyrods and ends,$50 15.24cc domes,cut for 4 mill,noss style,also machined for vitos..$20 16.Two clutch covers,water pump in one,$50 17.Stock crank,..Lil slop but ran fine..$65 18.Power Pro OOF,small bore,small flange with mounting hardwear...$300 19.Sand Skat paddles and rims 20-11-10..$165 If there is a local pick up price reduction can be made..951-823-3175 JB cylinders,and tranny sold
  2. try moving your clip to the middle... turn your air screws all the way in and then adjust them a full turn out and then another half turn...
  3. You dont need to change your jetting for the airfilter,But maybe for your t-5s...
  4. Pablo is one coohh cat!Weather is getting bad,I see a Twister in the future.. :biggrin:
  5. I was watching this bike on Craigslist for a while now..that is one sweet bike. .....Good luck,Free bump..
  6. Fresh black pcd T-5 Toomeys with sparkys that snap on and off..... By lowbuckracing, shot with Canon EOS DIGITAL REBEL XT at 2009-04-19
  7. The spindles or hubs are a lil different..I had trouble putting the front hubs on with the disc alignment..something is off..But all the other obvious is the same..good luck,JB
  8. Thanks to anyone who's helped me or tryed....someone hooked me up on my drag Build.. Thank's to whomever annomiously called Kevin from Herrjugs Racing and orderd the rest of my parts for my first Rigid "Lowbuck" Dragger..I couldnt get Kev to budge but thanks whoever it was..What comes around goes around!!!I will never forget.. Thanks,from the Lowbuckracing Family!!! By lowbuckracing, shot with Canon EOS DIGITAL REBEL XT at 2009-05-16 My Future Lowbuck Racer....In Training........2 yrs,She loves the banshees already.. By lowbuckracing, shot with Canon EOS DIGITAL REBEL XT at 2009-05-17 The Day after my life changed... By lowbuckracing at 2008-04-15
  9. John..send me your arm and I will tattoo you for freeeeeee,always hooking a brother up!
  10. Put a Banshee motor in it..part out everything else you dont need on it..Ive been wanting to do a tri-z banshee swap but havent found one to do yet..
  11. The flywheel gap needs to be adjusted..Put a buisness card in it and tighten down between the flywheel and pickup..Make sure the pick up has no rust on it also..If it does simply sand the surface,Make sure the card runs smoothly through with only a little resistance and try to run it..
  12. when did it happen?before or after your working on it..what all have you done ..Why did you change stuff out..More info..
  13. Did it run good before you left?What was the elevation change?Did you drive all the way with the bikes piggy backed?More info..
  14. 4mill,stock cylinder,dune port,35mm pwk-162 rd mains...sea level middle clip cek needle t5 toomeys
  15. Looking to trade them out for something of equal value..What do you have.....post pics! By lowbuckracing, shot with Canon EOS DIGITAL REBEL XT at 2009-05-09
  16. working on it...may have a hookup..Just waiting on the call....
  17. Kevs reply.."frame looks weak and the motor looks slow. Go pound sand!" :yelrotflmao: I think its time to start the "no show" thread...I will drive 2 hours out my way to pick you up......oh Ill save it for another day..The frame is weak and the motor is slow,bring that 10 mill to the track so we can all have a good laugh.. :biggrin:
  18. Cruise out from NY and you can test ride it....Just call first..thanks for the props fellas..Still need a few things... 1. radiator hose from the head to radiator 2.Chain for +12 swinger 3.Two teatherd kill switches 4.Rear brake cylinder that goes to the foot pedal,complete Front brakes,shocks and pivot bolt not needed..lol Thanks ..JB
  19. Killer deal....Wish I had the lettuce..
  20. Here you go brother..I had to send a stripper to your room..I had to make it decent incase your family has to read this to you..I will see you in Glamis again this year so get your azz better already! By lowbuckracing at 2008-06-16
  21. It would look like this.... By lowbuckracing at 2009-05-18
  22. Better get a seat belt for your banshee..LOL!!!
  23. pm torque-racing here on the hq..I think he selling some CPIs for around 400...Pretty new..
  24. I seen a few pair of pipes on PS...for around your $ range..Also 33s would work fine..
  25. Stock stroke?You can run stock carbs with bigger Jets for now..depending on how your planning for the future in your build,a set of Shearer inframes are a good pipe.t-5 or cpi would also be a nice choice...Ask Kevin what his port is gonna need to get the most out of it..good luck and a great choice on the machinist
