the problem probably is that you have DRAG pipes on a STOCK motor (just my guess) id reccomaend a pipe change in the near future, unless your planning on getting some more mods.
Is there anywhere that i can order a complete kit with the rods, pistons and everything? or do i have to order everything seperate? What exactly do i need besides the Piston kit and the rods? thanks
I probably wouldnt use a paper clip. They can scatch and gouge the inside of your jets, cusing a bigger problemthan needed. Take the nozzle and pit it right up to the jet and clear it out.
Well, Id just say go for the extra insurance, as has been repeated a few times. I dont know dajogejr, but as from reading nearley all of his posts, he is a very respectable man, and i would probably listen to him.
Do you like those shearers? I am mostly stock right now and am planning on geting a dune port and 33PWK's with pods. Can i get the pipes now and run them till i get it ported?
My back shock is really bad. It sags when you press down on it with little force. Is there any way i can tighten it or something? Like when i sit down on it, it makes me feel like i weigh 300 lbs. I only weigh 190 and it probably shouldnt be this bad. Is it cheaper just to get a new back shock?
thanks Guys
Hey fellas. My banshee is mostly stock. Im planning on getting my stockers dune ported in the spring, along with some PWK 33's. My question is that with my stock carbs and stock motor, can i run the shearer inframes until then? I want to put pipes on it, and get them out of the way right now. If so how big of a main and pilot would i need?
thanks alot
My swinger bearings were shot. So i got a bearing kit that came with the collar, needle bearings seals ect. But i cant get my old ones out. They are lodged un there and are really stuck. Any tips on how to get them out?
thanks guys
On my freinds 88', there is oil coming from the bottom of the spark plug. Its a brownish color. and theres alot of it. The sparkplughs are fresh and tight. What could this Be?
I was having the same problem. My shaft wasnt bent but the shift fork broke loose. Then somehow my idler gear bushings broke, and that was slapping the clutch basket. But we had to split the cases.
