If you give me your Zip code i can get you a number to contact the nearest hospital for you to give to your woman. that would be for future reference. thats crazy if you ask me.
I like my maier plastic. it looks better then i figured it would be. no scratches or flaws. fenders came from rockymountain and tank and grill cover came from ATV SPORTS i believe.
idk if there is a factory set for the idle but i went with what i think sounds good. its not to high but not low. it idles. i think it was set at 4 but i also have 35mm carbs.
and make sure they are set the same. you want to do it for idle and once that is set, set them with a little throttle so you know both carbs are opening up at the same time.
Below is a link to what you need. i actually think thats a decent price, but you should unplug the tors to see if thats the problem. if not then you know its not but i would also still get that mod to take that shit off your bike.
Ebay.
i just found a second kit for 4 or so bucks more that you dont need paypall for.
ebay
you tune it at idle to a equal measurement and then you give it some gas and measure it off idle. i put a piece of electrical tape in where the adjuster meets the throttle to give it a good steady rev then measured them so they are equal on each side. the tool measures the air flow being sucked into the carb. you just need to adjust the idle and adjust barrel hight on the top of the carb to make them equal. its a killer tool.
you can disconnect the TORS by unplugging the 2 wires from the harness to the TORS and unplugging the wire below and to the left of the gas tank. it will be plugged into a little black box that you can smash violently. your advantages are you will know if thats it. if it is or not i would get the kit to eliminate them. all you need to do is grill tap and screw in the idle screw. they come with detailed directions. its very simple. you can get kits with every thing included even the new throttle cable you will need.
with the last set of plastic i had i used magic eraser and wd-40. wd works nice. put lots on and rub it in good. you have to do it time to time but its the key :thumbsup: :thumbsup: :thumbsup:
The craptor plastic reminds me of them junk jap quads you see for $500 a pop. dont do it man. if your friends say do it its only so they can bust your ass for being a dumb shit when you do.
