Jayy
Everything posted by Jayy
This swingarm is off an 06 banshee bought new and was replaced after 10 hours use for an aftermarket swingarm. It includes the axle bearings and housing, and the front bearings/needle pivot bearings. It does not include the sleeve or pivot bolt. The axle housing and bearings have not been removed from the swingarm or even loosened to adjust chain slack. It is in excellent condition. I will include pics as soon as i can get some up.
These pipes have maybe 30 hours use. No dents well cleaned and cared for. No bluing. Pipes are still on bike stored in garage right now, but will provide more pics if needed. Here is one pic to give you an idea how they look. As you can see, I take care of my stuff. I am only selling these because I want to try something different.
Can provide pics if requested. All parts in outstanding condition. I bought an 06 new and immediately started modding. All of these parts have no more than ten hours use on them. Stock axle is 75.00 shipped. Stock front shocks 50.00 shipped. Stock rear shock 100.00 shipped. Stock pipes and mufflers 50.00 shipped.
Damn! I just missed a sale for a set in the for sale section. Anyone else have any for sale?
Anybody have any for sale in decent shape? Would like to find the pipes and the PT fatboy silencers. Thanks.
I am glad you asked this. I also just put in a FAST clutch and am wondering the same thing. The install went great, but my bike has an aftermarket lever and I am wondering if I dont get enough pull either. My plate is adjusted correctly, but I have run out of adjustment at the lever and the bike wants to creep when I put it in first.
Thanks, Animalman. Yeah, The intake is not stock. This bike has a custom fab aluminum airbox, no lid, and huge 2.5 inch aluminum breather tubes going to the carbs. The filter is a twin air filter off of a YZ 250 dirtbike. The motor is stock port, +4 timing advance, Pro Circuit pipes, but it breathes WAY more than a stock shee. The plug chop above was with 340 mains, stock needle on center clip, and 27.5 pilots with airscrews 3/4 turn out from seated. It runs clean through to the top and I have tried the choke trick at all throttle positions and speeds and it bogs whenever I pull the choke. I think it is jetted ok/safely rich, but the difference in how this thing breathes makes me hesitant.
Anyone?
Anyone?
If you look close, the ring is there, but hard to see because the entire center electrode is darkened quite a bit. This was with 340 mains. When I ran with 320 mains you could see the ring better because the entire electrode wasnt darkened from one chop run. Are you sure its not rich?
Hi, everyone. I just took pics of the plug chop I did on the outlaw chassis mx shee I am building. It revs out cleanly and I think I am rich enough, but could I be too rich? This is a proper chop after WOT in sixth on new plugs. The darkest ring around the base of the electrode didnt get that dark all the way around, but there is a dark ring there. It is hard to tell the smoke ring went all the way around the base because the entire center electrod was darkened. Let me know what you think. One side. Opposite side.
Thanks, Washburn. Yeah, Jeff is great and has awsome service. Thanks for the compliments on the bike. I am loving it so far, it is definitely different.
Ok.... There has GOT to be a story behind that! :biggrin:
Hi, everyone. I just wanted to give a big thanks to Jeff at FAST for his awsome customer service. He is a top notch guy. He took the time to answer questions and give me tips on the parts I am ordering and mods I am doing. A lot of you know I am working on a Banshee/250R Hybrid MX framed shee. The chassis came from a member here (Broke) and I found an 03 motor to put in it. Things are going well with it, but I noticed I could not get my clutch into proper adjustment at the lever or at the adjuster on the clutch plate itself. I decided as time goes on and I do more mods to this motor I want a stout clutch that can take whatever I might add, so I went with the FAST racing clutch. I also picked up a modded shift star, softer spring for the detent roller, new gasket, grab it tool, sprocket, etc. The shifting was notchy on this motor to start with and neutral was hard to find (typical banshee). When I put this motor in the frame I had to cut 3 inchs off of the stock shift lever length and reweld it to get it where I needed it. That made the shifting even worse because I have less leverage to shift with. I am expecting this will make it great. Anyway, I am including a couple of pics of this crazy bike I was describing to Jeff in case he checks out this thread so he can see what I was describing to him. Thanks again, Jeff!!!
