98 banshee
new rebuilt motor 65mm 38mm carb2 into 1 trnity K@N pod
2into1 pipe ewww sounds good though
extended axel , exteded a arms holeshot tires polished douglas rims
black plastics , fresh black frame, pretty fast bike for the setup runs good
pm me if interested ill get pics up later
your best fix is free , take the kicker off theres a little ball ...hold that, take out the spring take 2 pairs of pliers and pull the spring a little till its longer than before and put it back in. and put the ball on with grease and hold it in place slide the kicker back on and it will feel like new again
stock tie rods
stock front shocks , not blown that i know of
stock rear shock
dog bone linkage
06 swing arm with skid plate
stock front rims and tires 45% tread lightweight
rear polished douglas wheels with dure flat track tires , one ride on them like new
front hubs needs bearings comes with nice rotors
rear sprocket new 44tooth wtih hub
kick start gear
powermadd red hand guards
stock rebuildable crank
stock clutch cover bare \
yfz 450 footpegs with guards
master cylinder works but has play in lever
i have a set of perfect cases 160 firm
stock air box with 2into 1 cnc adapter
resevoir bottle
man i hate you had a bad experiance with that , i run robs stuff and he may be a little ill at times but he ports out massive power and my port job on my 421 is so clean it would cut you , im still gona back up rdz
you gona be on pavement ? for one thing you need to get rid of that 13 tooth front sprocket and at least do to a 15 . i run 15 41 with 20s and its not near enough gear , traction is everything if you cant get the power to the ground its no good ,
has anyone ever had a set of cases chromed , polishing is just to much work and dulls out quickly .
yea i know the saying chrome wont get ya home but looks good pushen , but man it looks good
i have a set upper and lower yfz 450 a arms blue , they are in good condtion except the threads got messed up on the ball joint on 1 , a new ball joint would fix it , would make a great banshee conversion , will add 2 inchs per side
150 shipped
