ScEaMin BaNsheE 305
Everything posted by ScEaMin BaNsheE 305
Helpful tools for the build
ScEaMin BaNsheE 305 replied to PaymentPlan's topic in General Banshee Discussion
get bolt that fits then use a small pipe wrench to loosen -
cpi small bore in-frames, 27.5 pilot, 4th clip on needle, 330 mains. Im pondering if its possible that a float needle could be adjusted wrong and starve the engine of fuel at WOT, I did mess with it trying to get the fuel to stop pouring out the overflow, the other piston looks good so im thinking that the root of the problem lies in the float adjustment of the carb on the side of the blown piston, I appreciate the feedback, btw I did a leak down before riding and after I blew the piston and it held 6 psi for more than 10min. Thanks
64mm stock pistons, no porting chariot cool head with 21 cc domes, vf4 reeds, chariot intake manifold, k&n pods, +4 timing, running 93 octane. So I already put a hole in a piston but to avoid the same shit from happening again, do I need to change the jetting to richer when running +4 timing and 21cc domes or did I fuck up by running 93 gas. thanks
nice i need those brackets, are you making more and how much for a pair.
yep have done the research just needed to confirm on how to float the ground but will have to go with my gut on this one, next mission is figuring how to cut up those led lights to fit
how do i go about floating the ground, from what ive researched it says to cut a wire on the stator, do i connect that wire to the ground of the rectifier, if somebody could confirm the correct way it would be nice
go on atvflorida.com
How those darn Quad Dealer Ships Scam Us
ScEaMin BaNsheE 305 replied to MULLET~BOY's topic in General Banshee Discussion
so the tottle oh i mean Total price is 30,000 -
just turn off auto-correct altogether
CPI In Frame pipe question - stock fenders
ScEaMin BaNsheE 305 replied to Flyinrazrback's topic in General Banshee Discussion
i have cpi's with fenders, all i did was add little brackets to extend fenders out about half inch, you can also let them melt to fit -
New Used 2006 Banshee Fluids Change
ScEaMin BaNsheE 305 replied to Youngboy856's topic in General Banshee Discussion
cant help you there i live in miami, never seen snow- 6 replies
- Engine Ice
- Redline 2 Stroke Oil
- (and 3 more)
engine ice good , i use belray 80w gearsaver oil and yamalube 2r 2stroke oil since 2006, try rockymountainatv.com best deals on chems in my opinion- 6 replies
- Engine Ice
- (and 3 more)
that handle bar pad cut out for temp gauge is good idea, shit now im debating whether to get the 19 or 22 mm tto
Billet shift star
ScEaMin BaNsheE 305 replied to ClaudeMachining's topic in Banshee Repairs and Mods
a splash guard for the kn pods would be great -
Only starts on lubed starting fluid...
ScEaMin BaNsheE 305 replied to new2the'shees's topic in Banshee Repairs and Mods
raptor plastics, i get it now -
Question about plug chop
ScEaMin BaNsheE 305 replied to hercalmighty's topic in Jetting & Exhaust Forum
how much does a promod tranny go for? -
When to change a water pump?
ScEaMin BaNsheE 305 replied to SoonerFanAZ's topic in General Banshee Discussion
what ⇧ -
rip that shit out, so much better without tors except when u hit water hard, throttle sticks wide fuckin open, just hold on tight
i change my impeller, seal, and bearing every 5 years just to be on the safe side -
Problem is fuckers never try doing research first or try opening the clymers manual, i rarely post for help bcuz answers are already in the forums, ive learned how to fix the banshee (easiest machine to work on in my opinion) , if you cant fix ur shee on ur own then u should take it to stealership or buy a mountain bike. I love BHQ, thanks for keeping the forums running.
Clutch side of the motor was making noise.
ScEaMin BaNsheE 305 replied to 03banshee88's topic in Banshee Repairs and Mods
did you check the inner clutch hub nut, remove six screws with springs from pressure plate, nut is under there -
Best of craigslist..................
ScEaMin BaNsheE 305 replied to Blownyel93's topic in General Banshee Discussion
How does one go about to become a certified adult
