1996dragshee
Everything posted by 1996dragshee
  1. gotta sell.Tyson converted with adj powerjets dumps at .120 the carb caps/slides and needles do come with em... oh these are snomo style carbs. I have a pump only ran for a few months for another 20 325 shipped for the carbs/filters or 345 for all of it http://p1.bikepics.com/pics/2009%5C07%5C30...740750-full.jpg
  2. air/fuel screw and sync your carbs.check your plugs...
  3. Bump for a good deal right here!
  4. I don't want to but don't have a choice at the moment.need the cash... Sorry no pics yet but here's some prices... Port Magic (Rudy Kurtz) drag ported 10 mill T-rex cylinders fresh resleeve 75mm bore not ran since, t-rex coolhead with domes,brand new base gasket and coolhead o-ring kit,my 76.5 pistons for future needs,v-force reeds & intakes,powervalve block offs....you will need to get pistons for the new 75 bore. $1000 shipped plus paypal fees. Costed me almsot 7 to resleeve it and i payed well over that when i bought them... Oh these are capable up to a 78 bore now i was told smile.gif 39 pwk snomo alky carbs set up by Tyson with 14" filters & powerjets- $350 shipped...I also have a pump for another 20.Ran these half a season since converted Raw Big Bore Big Flange hand coned 2 out the right side Shearer pipes...bad azzzz pipes...I have both bolt on silencers and stingers for them.Currently for o-ringed cylinders- $450 shipped Tyson 1-5 override with newer second gear and new shift drum.maybe 30 passes on my 4 mill with this tranny.N between 1&2 (stock) 325 shipped LSR aluminum drag axle with all banshee hubs.The outside splines are a bit worn but the middle and inner are good to run - $350 shipped Direct Drive lockout and old school polished Tyson cover- $220 shipped Will get some pics asap but those who knows me knows i don't have/run junk
  5. lmao
  6. Ill pass on the offer.its gonna cost me at least 25 to ship it lol
  7. You said this is a stock stroke/rod length crank with stock stroke pistons right? Sounds like you have some huge deck height numbers. Measure the deck height right now with the head off and then pull that fucker apart and measure the thickness of your base gasket and also measure the step in the dome are of that head.If the edge of the crown is hitting the head than either that head was shaved down pretty good and that head gasket is a .021 or that base gasket you have is like a .012 or something.Either way if you measure the deck height and all the rest and do some math than you can get the ballpark of what thickness base gasket and or head gasket you need to get the proper squish clearance you need My bad i assumed that the compression check was done with another head gasket on.So yes your compression numbers would be real low in that case with no head gasket.And also after just thinking while typing this,You heard the piston slap the head when you checked the compression with no head gasket on? Because that right there could be the cause of your piston hitting the head...they do make different thickness head gaskets also. Sorry if it is a stupid question but i'm just trying to clear things up a bit
  8. squish is too tight man.Did this guy even run this set up or just slap it together and sell it? You need a thicker base gasket. And 100 psi is very low.May be time for some new rings too
  9. I havn't personally ran this particular set up but i hear good things on them.Some people arn't a fan of vito's products but i had a 4 mill monoblock cylinder pushing in the range of over 100 hp.I wouldn't hesitate to run another vitos cylinder, i was happy with it.
  10. At 1000 ft i don't see you being over 300 mains.For stock pipes and no porting there really isn't a reason to be over 25 on your pilots. The idle is the least of your problem.That can be fixed with the turn of a dime.Stick with them 290s or 300s and lower the clip one notch.You're right around ballpark just gotta tweak it a bit. My ol' ladys banshee runs 190 mains and 27.5 pilot while my father in laws Banshee runs 300 mains and 27.5 pilots both piped,no porting, and air box drilled with K&N's.In Michigan about 750' above sea level i think and about 75 degrees...I know shit is way off but they both run friggin top notch lol
  11. Alright before i ramble on,are these the vito's bb sleeper cylinders or is this the monoblock? I thought it was the 404 monoblock but from what you stated about the head i'm assuming stock head so these would be the 68 bore sleeper cylinders? That 66 head gasket isn't the correct gasket for them cylinders.66 is still considered "small bore" . You need a 68mm head gasket,vitos has them. I would toss the head back on and check your squish and compression and go from there.Has the head been shaved? It could also be warped....
  12. Possibly an air leak. What domes,compression and squish do you have? Edit: ditch the boost bottle and get a stock crossover tube.Better yet,get a billet intake to match that cylinder!
  13. With your mods listed you should pass
  14. Nice trail pipes right here. Good luck on the sale Bump!
  15. Definitely to much tire.If they were a smaller roll out say a 70 or so like the kevlars that Fouledout listed in the link above, they would be some what suitable.But being a 73 roll out for a dune port set up..man that is a lot of tire to turn. You could gear down but what's the fun in that when you would have to worry about keeping the front end down.Either way it's to much tire IMO
  16. Damn nobody wants this thing....
  17. Lol what the fuck...This must be from one of them 4 mill banshees he lines up with on his honda
  18. You're compression is right on the money.If you got spark,compression and fuel than it's just a simple problem.I would pull the air box lid and filter off and spray a couple shots of starting fluid to the carbs (thottle open) and give it a few good kicks. I'm kinda confused on the longer pilot deal though.I've never heard of that. Either way,if it starts on starting fluid at least you will know it is a fuel issue.
  19. PM sent
  20. If they are in fact pwks than you are stuck with them being alky carbs. Once they are set up for alky there is no going back to gas on these carbs.As stated they are drilled and obviously you cant put the material back in. Contact the seller for a refund and/or open a claim stating they're not as described or just list them back up for sale staing what you know about them
  21. whats the total price shipped to 48066?
  22. Someone should just email him this topic link of bashing on his sale.Maybe he will revise his listing and actually post it correctly lol.What an idiot
  23. 75 shipped...Still in good shape.I've ran it since i've had the bike with no problems...
