methyman
Everything posted by methyman
  1. I have two sets of PWK39 mm carbs. One set up for a pump and the other set up for gravity feed, both have billet bowls with super jets. $450.00 shipped anywhere in lower 48 states.
  2. I didn't advertise them for sale. You don't have to buy them. They will sit in my toolbox waiting to go into another banshee motor soon. I was just trying to help out a fellow HQ member. Oh well no loss. Good luck finding reeds.
  3. I have a set of VForce 3 reeds for sale $155 shipped, pedals are in good shape.
  4. I have one on my banshee that I bought from this Ebay Guy It fits perfect no problems at all with it. He is in Florida and not over seas.
  5. 16mm or 18mm pin?
  6. The old Shearer pipes had a problem with the left pipe hitting the head. The new pipes do not have this issue because Mat addressed this issue on the inframe pipes.
  7. Bore doesn't give you as much power as a good port and polish. The smaller motor can out run a slightly bigger motor if it set up correctly.
  8. I have a set of gravity feed and another set up for a pump both with billet bowls and DMR super jets. $350 shipped for a pair.
  9. You can get a new one from M&M ATV http://www.mmatvonline.com/product_info.php?cPath=26_27_22&products_id=33
  10. Yes. Better bearings than stock. Max load is 10 bearings instead of 8 being stock, The TZ is a flat roller bearing. Which is on all my cranks.
  11. Small bore. The big bore inframe pipes were designed for the 535 cc Cheetah.
  12. I have a used Hot Rod 4mm stroker long rod with max load bearing on flywheel side and tz on out put side for $320 shipped.
  13. Buy direct from Mat Shearer! Sand Toyz Unlimited sells nickle not chrome! http://www.shearerpipes.com/
  14. I have some 38 TMX Mikuni carbs on gas for $200 shipped within lower 48 states if interested.
  15. Here are some used VForce 3 Reed cages $120 shipped
  16. I have a round carrier for stock axle $85 shipped.
  17. The only way the pipes will work if they are big bore pipes. 535 needs big bore pipes.
  18. methyman
    pipes wanted
    you got a pm
  19. methyman
    pipes wanted
    I have a set of two out the left small bore shearer drag pipes, chrome and have egt fitting in the pipes. A couple small dings on the bottom pipe, pipes need to be welded around mounting brackets.
  20. Yes
  21. I have a set of Keihin PWK 39mm carbs with billet bowl, power jets set up for methanol. Ran them on my 10mm DM motor and my 10mm 535cc Cheatah motor. $450.00 shipped. They are set up for gravity feed. I ran 1/8th mile with out a pump. Later Matthew [email protected]
  22. Check this out! http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320604303206&viewitem=&sspagename=STRK%3AMEWAX%3AIT
  23. Bought a flywheel from him and it was shipped quickly and just as pictured in the post he had put up. Thanks Matthew
  24. I have some Shearer small bore two out the left chrome, some small dents on lower pipe, pipes have been re welded at brackets where pipes mount together. They need to re welded the have a small leak at weld. They have the fittings for a EGT on the pipes. $400.00 plus shipping which is around $45.00.
  25. Out of frames?
