NOS_350x
Everything posted by NOS_350x
  1. I got a set of 34mm Flatslide Mikuni carbs and im a Keihin kinda guy. so i wana trade. Lookin for something comparable. Also, woudnt mind some alky carbs.
  2. For Hoosiers its diffrent. They only come in 10's well at least thats all i can get around here. As for nobbies i stick to the 8's. That all depends weather your running on a cushion track or clay. With the 8 in rim you get more sidewall roll. this giving you more side bite and it helps in the turns to get more traction, it really helps when you got alot of HP your trying to get to the ground. Motodrummer, If you take off your front lowering kit you will get alot better rear wheel traction. And for that R, You dont need a puma to run with the 450's a good ported stock cyl can hang with them.
  3. Here are the pics, the boots over the balljoints are slightly torn, and im missing 2 dustcaps (i can probably find those if needed) No bends or dents i can find.
  4. Ya ya little late notice, but its better than none.
  5. Who makes them (and there websites please) All i can find is Direct drives website. Im lookin to get 2 of them One for the flattrack bike and one for the drag bike.
  6. Im not too shure with ice. But when it comes to clay or dirt, The larger the rim the less side-bite you will get. I try to stick to 8's because in the turns and comming out of them it hook up soo much more.
  7. Ok, Ill pull them off the shelf tonight and check them out. Then get back to ya. but ya they arnt bent or anything.
  8. I got a set of stock a-arms. they where all good when i took them off, The front of one of the sides is sand blasted perty bad from racing. but mechanically they should be just fine.
  9. YUP YUP, along with ASR and Jannsen. Sad one company makes them and everyone elce just throws there sticker on them.
  10. Myspace.com/imhalfevil i can be found there every once and a while
  11. How much for just the FatBoy 2's dont need the pipes.
  12. After my first run on them, The mids seem to pull so much harder in the mid range. The high revs dont seem to pull hard anywhere. but the high revs just carry it in the rpm's The mid range falls off up top where the high revs continue to pull.
  13. Well i can tell you the difference in the 2 in just a few days. The interesting part is the Left side pipe, the "fatness" is the same as the Mids, the only difference is the stinger on the Highs seems to be a bit longer (the twist is a bit tighter but the tapers seem to be the same on the 2) Where the left side is a hair larger, and bends are way different.
  14. Im going from PTR Mids To high revs. Pulled off my mids and started comparing, Are my HIGH REVS NOT suppose to be symmetrical? My left pipe is ALMOST identical to the mids, And the right side is quite diffrent. Is this normal or maby a miss taged pipe? Pictures of high revs on both sides of the bike would help too if any can get that.
  15. So are you trying to tell me that bike with the same porting that has OOF drag pipes and you swap to a 2 into 1 pipe Its not going to lower the rpm where your powerband hit is? Its easy to change pipes to a lower hitting pipe, But you cannot change your porting once you go to a top end port.
  16. Ptr's would drop that drag motor down alot. A dune port shouldnt be ALL on top. So you get some low to mid pipes and hopefuly you hit a happy medium.
  17. These arnt radial car tires, If you keep the kind of pressure you want to put in them in 6 months they will strech big time,your going to gain an inch or two. From keeping that kind of pressure in them.
  18. I ONLY run the Maxima's Castor 927, I pull off my pipes and the exhaust port has ZERO carbon buildup, pure oil in it. I mix at 32:1 Its easy and very safe. The only other oil i will recommend is Motoul 800, Thats some good stuff right there too. I have used every oil mentioned and many others, and none of them are as clean as these two.
  19. SOLD, Send me a email addy and ill paypal you the money.
  20. WOW dude talk about over inflateing them. Dont exceed 35psi WHEN SETTING THE BEAD!!! MAX operating pressure, is 15 lbs I never exceed 6 psi, but normaly run in the 3-5 psi range.
  21. I acutaly like IE better, But for Youtube or downloaing things firefox is insanely fast compared.
  22. got a set of Duncan Racing 34 Pj's For your mods they would work perfect.
  23. a 33mm is small for that get a 38 with the single and it will probably make you happy. I have a set of 37's i might trade for everything you got but not going to trade my manafolds and cable with it, IMO the 2 into 1 isnt worth nearly as much. Im from kingsburg too.
  24. I wont touch mikuni's i hate them, I dont get emails on the pm's for some reason?? I was looking at Sudco, i buy stuff from them about 2 times a year, but i find them overpriced for alot of parts.
