Snopczynski
    2
  1. Ummm, no! Peak operating rpm on pro circuits is about 8600-9000 rpm. ZThe bike is eye blinding fast, and I am quite impressed and happy with how it runs. Thats why I had it ported like that.
  2. I ride the Oregon dunes with a trail port job.
  3. This is not entirely true, there is a year the banshee hubs are different. So, what year is the banshee, and what year warrior did the wheels come off?
  4. Dynoport did mine, it was $500 and it pulls really hard from 5krpm to 8600 rpm. (limited rpm because of my pipes). I do my own trail porting now, haven't finished the first motor yet though. The key component to bottom end power here is good 165-175 range compression.
  5. I was at Dan's from Patriot Racing today. He was putting a stock clutch back in a motor he had on the bench and he said he doesn't put the o-rings back in them.
  6. word on the street at xbox.com forums is there will be an update soon for the game. I dont know what it will address though.
  7. I like the p90 with a silencer. they dont hear anything and start running around looking for me while I hide in a bush.
  8. Throw a rug over it.
  9. I dont know, I only played bf2 on pc. Does ps3 have a wireless adapter yet? Xbox has one and it works decent. Is there a way to tuck the cat5 under the baseboard?
  10. wiring internet is pretty easy. I did my whole house myself. I just bought a box of cat5e and ran it under the baseboard inside, tacked it to the wall on the outside like they do with coax. Get two jack ends for each end and punch the cable in. Hook up to the router and your set.
  11. I remember that name from halo 3.
  12. So your on PC?
  13. Are they standard skat's, or are they super lites?
  14. Its a 250r cable, call cascade.
  15. Play domination on "shipment".
  16. You cant run stock pistons if you dont have a spacer plate. I have never seen someone cut a dome 4mm and then rechamber it to be the right size. This guy says he doesn't have a spacer plate.
  17. that cheetah motor was resleeved and had the exhaust ports reported and moved down. The pc's showed more peak hp yes, but they also had a bigger torque curve on the 6 mill motor. Technically though, the ptr's pull higher rpm, so they should make power longer and further up. The pc's peak at 8600 rpm.
  18. the end cap has a snap ring, pull it apart and put new packing in it.
  19. dont put in the rubber o-rings. If you got a manual check it, it will show you how to stagger the steels.
  20. Its any two primary weapons with overkill. Most of the time I roll with perk 1 as 3x grenades, perk 2 as stopping power (smg's, assault rifles, snipers) or double tap on my light machine guns, and shotguns. Perk 3 is usually deep impact, steady aim, martyrdom, or iron lungs depending on which primary weapon I am carrying. Like on my snipers though, I carry a sniper rifle, with stopping power and iron lungs or deep impact. Then I carry the gold desert eagle as a secondary weapon. If I get in a map and have to move around a bit, I will ditch the deagle for some dead guys gun like a m4 and shoot everyone up to get where I am going.
  21. I strongly disagree, if your doing trail riding and want botttom-mid power the pro circuits are by far the torquiest pipe on the market. In all the dyno testing we have done in the last year, the pc's decimated everything hp and torque curve wise on bottom-mid ported motors. Hell I even saw a dyno run on a 460cc 6mm cheetah motor where the pc's beat out a set of ptr mid's by 5 hp, and had a bigger and better torque curve. This is one of the main reasons why halfway through the summer I switched over to pro circuits.
  22. I say ditch the 4 bolt hub. If your ever in a jam and need a sprocket, they are less common to find than the 6 bolt hub sprocket.
  23. 22x11x8 10 paddle super light.
  24. The only other way I can figure he did it without a spacer plate is with blaster pistons. Pre-ignition or detonation would damage the piston dome and head domes.
  25. p90 is rank 40. Overkill, which I barely even used is rank 38.
