Lethaface
Everything posted by Lethaface
  1. THIS IS WHAT'S LEFT!! CARBS, SEAT AND HELMET ARE ALSO ON EBAY RIGHT NOW 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clampon K&N filters and a Dual Feed Pingel and dave moore super jets. $400 Bowls had a 1" x 1.5" extension added to them for more fuel. They was welded then industrial strenth epoxy was used to insure no leaks. $400 shipped. 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also come with a +6 stainless steel brake line. $200 shipped 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $30 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $110 22. Front hubs. One stud has a small cut/grind into it has a stripped lug nut had to be cut off. It doesn't effect it though and nuts thread on fine with hand. Could be replaced but worked fine. $50 34. KBC gunslinger helmet size XL. very good shape. $110
  2. Thanks got the money. The carbs are alky carbs. There is more info and a pic on them on ebay if your interested in them. They are at a $300 bid right now. Thanks, jeremy
  3. THIS IS WHAT'S LEFT!! CARBS, SEAT AND HELMET ARE ALSO ON EBAY RIGHT NOW 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clampon K&N filters and a Dual Feed Pingel and dave moore super jets. $400 Bowls had a 1" x 1.5" extension added to them for more fuel. They was welded then industrial strenth epoxy was used to insure no leaks. $400 shipped. 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also come with a +6 stainless steel brake line. $200 shipped 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $30 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $110 22. Front hubs. One stud has a small cut/grind into it has a stripped lug nut had to be cut off. It doesn't effect it though and nuts thread on fine with hand. Could be replaced but worked fine. $50 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $40 34. KBC gunslinger helmet size XL. very good shape. $110 Billet Case saver. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever, Stock Thumb throttle with polished Cap. Harness still attatched SOLD TO FARMER!
  4. Yeah dave i will take $25 shipped for all the bolts. My paypal addy is [email protected] Thanks, Jeremy
  5. The bolt set is pretty much a entire banshee minus a few bolts that need to go out with certain parts like the sterring stem clamp bolts. There is a good bunch of allen head bolts in there though.
  6. Yes they are there.
  7. Yeah i can do that. All the mounts are there. The rear bolt, the bottom strut type and the 2 plates that bolt to the frame and then have the bolt that goes threw them. Paypal addy is [email protected] Thanks, jeremy
  8. Whats left 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clampon K&N filters and a Dual Feed Pingel and dave moore super jets. $400 Bowls had a 1" x 1.5" extension added to them for more fuel. They was welded then industrial strenth epoxy was used to insure no leaks. $400 shipped. 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $25 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also come with a +6 stainless steel brake line. $200 shipped 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $30 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $110 22. Front hubs. One stud has a small cut/grind into it has a stripped lug nut had to be cut off. It doesn't effect it though and nuts thread on fine with hand. Could be replaced but worked fine. $50 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $125 27. Motor mounts and motor mount bolts. This will be upper and lower as well as strut mounts. $20 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $40 32. Stock Thumb throttle with polished Cap. Harness still attatched $30 34. KBC gunslinger helmet size XL. very good shape. $110
  9. Nah nobody picked it up on the atv sites. I got it on fleabay right now so maybe somebody will pick it up there. The case saver isn't bad at all. I just mentioned the part that was removed so potential buyers wouldn't end up with something they weren't expecting. Anyways I'm working out a trade on a Tmaxx and the buyer possibly wants the case saver. I will know something for sure by tommorow and maybe we can work something out if you havn't found something else. Thanks, Jeremy
  10. WOW! I have never had any problems with mike. I was trying to make a race last season, the pods were on back order so he pulled a pair of the crankenstien bike and mailed them to me so i could make it. Something bad must be going on or something. I was curious why i couldnt get a hold of him the last couple months. Anyways, sorry to hear about you guys, bad luck. I hope he make's things right with you guys. jeremy
  11. Well keep it going and get mom and dad some Alky carbs and grandma and grandpa a swingarm lol.. J/K Anyways guys here is whats left. I have dropped the price on alot of this stuff to get it gone. Really need this stuff to be gone within the next two weeks.. 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clampon K&N filters and a Dual Feed Pingel and dave moore super jets. $400 Bowls had a 1" x 1.5" extension added to them for more fuel. They was welded then industrial strenth epoxy was used to insure no leaks. $400 shipped. 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $25 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also come with a +6 stainless steel brake line. $200 shipped 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $30 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $110 22. Front hubs. One stud has a small cut/grind into it has a stripped lug nut had to be cut off. It doesn't effect it though and nuts thread on fine with hand. Could be replaced but worked fine. $50 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $125 27. Motor mounts and motor mount bolts. This will be upper and lower as well as strut mounts. $20 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $40 32. Stock Thumb throttle with polished Cap. Harness still attatched $30 34. KBC gunslinger helmet size XL. very good shape. $110
  12. Np, It's yours man lol.. Yeah he has talked about how easy you are to work with. Np though man until monday, go through that updated list and see if there is anything else you need lol
  13. Well here is what's left fellas. 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 22. Front hubs. Good shape one of the studs could use a replacement as it has a small cut in it(stripped bolt had to be cut off) But i used it with no issues. Goeed bearings and seals $40 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 34. KBC gunslinger helmet size XL. very good shape. $120 35. Steering stem. Good shape, straight! $50
  14. Yep, it's not one of the floppy ones that clang around and makes noice. Works perfectly!
  15. Nope no chrome man .. It does look good. My little bro did all the work on it.
  16. I still have the kicker. If your interested pm me and let me know.
  17. They are in the box in a zip lock bag. They are probably down in the bottom of the peanuts
  18. back on the scene with a gangsta lean here is whats left guys.. Really need this stuff to be gone within the next two weeks.. Will accept reasonable offers but i'm somewhat firm. 3. Pro Design Cool Head shell. No domes $110 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 33. Chrome Rear brake Lever and Shifter. VERY NICE! $60 34. KBC gunslinger helmet size XL. very good shape. $120 all parts off my very clean '99 shee. __________________
  19. Thanks man, Glad you like it!
  20. The splines are very good.. It is off a 04 so it is fairly in new condition.. The whole family is fighting off a stomach bug right now but i'll try and get you a pic by saturday if you need one.. Here is a pic from a little bit of distance. It shines a little better than the pic shows.
  21. 3. Pro Design Cool Head shell. No domes $110 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 19. Complete set of Special Edition Yellow Plastics. Comes with a one of a kind Texas Chainsaw masacre Graphic Kit. Also comes with a custom made Chainsaw grille. This is the only Set of graphics and grille like this in the country. Plastics are in very good shape.. Not scratched up and beat like a trail bike. $300 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 24. MSR Adjust on the fly clutch lever. Comes with a brand new MSR terminator Ceramic clutch cable. $50 26. Complete set of drag wheels and tires. Will come with a set of ITP rear wheels with Hoosiers and a set of 4" douglas front wheels with drag tires. Very nice wheels not bent or dented up. $350 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 33. Chrome Rear brake Lever and Shifter. VERY NICE! $60 34. KBC gunslinger helmet size XL. very good shape. $120
  22. It's just a stocker i put alot of time into.. I'll try and get you a pic by tommorow the rest of the bike is over at my mom's place in her shed. Jeremy
  23. The stock head you have is has been milled and rechambered twin. no he has a vito's BB setup in a set of stock cylinders. There is a ton of work in those cylinders, hope he can find a head for it..
  24. Other thread is a bit to cluttered. Really need to get this stuff gone, going to buy my mustang sunday so i need money for the 347 stroker kit lol.. Accepting best offers on the rest of this stuff.. Thanks, Jeremy 3. Pro Design Cool Head shell. No domes $110 6. Flow Tech 12oz Lightened Flywheel Good shape LOOKS NEW! $100 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 19. Complete set of Special Edition Yellow Plastics. Comes with a one of a kind Texas Chainsaw masacre Graphic Kit. Also comes with a custom made Chainsaw grille. This is the only Set of graphics and grille like this in the country. Plastics are in very good shape.. Not scratched up and beat like a trail bike. $300 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 24. MSR Adjust on the fly clutch lever. Comes with a brand new MSR terminator Ceramic clutch cable. $50 26. Complete set of drag wheels and tires. Will come with a set of ITP rear wheels with Hoosiers and a set of 4" douglas front wheels with drag tires. Very nice wheels not bent or dented up. $350 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 33. Chrome Rear brake Lever and Shifter. VERY NICE! $60 34. KBC gunslinger helmet size XL. very good shape. $120
