Everything posted by Lethaface
Updated list! 3. Pro Design Cool Head shell. No domes $110 6. Flow Tech 12oz Lightened Flywheel Good shape LOOKS NEW! $100 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 19. Complete set of Special Edition Yellow Plastics. Comes with a one of a kind Texas Chainsaw masacre Graphic Kit. Also comes with a custom made Chainsaw grille. This is the only Set of graphics and grille like this in the country. Plastics are in very good shape.. Not scratched up and beat like a trail bike. $300 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 24. MSR Adjust on the fly clutch lever. Comes with a brand new MSR terminator Ceramic clutch cable. $50 26. Complete set of drag wheels and tires. Will come with a set of ITP rear wheels with Hoosiers and a set of 4" douglas front wheels with drag tires. Very nice wheels not bent or dented up. $350 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 33. Chrome Rear brake Lever and Shifter. VERY NICE! $60 34. KBC gunslinger helmet size XL. very good shape. $120
go to photobucket.com Create a account.. upload pics there.. After uploaded you will have a couple choices of how to host your pic.. One for email, one that is html and another that is IMG.. Choose the IMG and copy and paste it into your threads..
1. 421 68mm cheetah cub cylinders with pistons and wrist pin bearings $750 2. Hot Rods 4mm Longrod Crank like new 3 weekends on it. $350 3. Pro Design Cool Head with BB 18cc domes $170 4. RDZ 1-5 override with neutral down. PERFECT SHAPE! $400 6. Flow Tech 12oz Lightened Flywheel Good shape LOOKS NEW! $100 8. Majic Performance Lockup and polished Lock up cover. $300 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 11. Trinity Stage lV intakes for 38-40mm Carbs Also comes with a extra set of boots that fit a 34-36mm carb. No issues like cracking or anything like that. $140 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 17. Axle Carrier from a 04 with brand new bearings and seals. $45 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 19. Complete set of Special Edition Yellow Plastics. Comes with a one of a kind Texas Chainsaw masacre Graphic Kit. Also comes with a custom made Chainsaw grille. This is the only Set of graphics and grille like this in the country. Plastics are in very good shape.. Not scratched up and beat like a trail bike. $300 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 21. Complete set of a-arms, spindles and tie rods. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 24. MSR Adjust on the fly clutch lever. Comes with a brand new MSR terminator Ceramic clutch cable. $50 26. Complete set of drag wheels and tires. Will come with a set of ITP rear wheels with Hoosiers and a set of 4" douglas front wheels with drag tires. Very nice wheels not bent or dented up. $350 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 33. Chrome Rear brake Lever and Shifter. VERY NICE! $60 34. KBC gunslinger helmet size XL. very good shape. $120 35. Working CDI from a 99. $55 36. Coil, Wiring harness and voltage regultor $55
Kawi, He was my only competition.. he parted out to get married so the closest bike was running 9.10's lol.. So i decided to just do a car project.. Few more things i didn't have pictures of earlier. Sprocket and sprocket hub Modquad bar clamp Chrome Shifter, brake lever and kickstarter. Trinity Stage lV intakes for 39mm carbs and extra set of boots for 34-36mm carbs
A-arms and spindles gone.. Will do a packaged deal on the cub set up.. Will include Cub cylinders, Stroker Crank, Cool head, pistons and domes for $1225 shipped plus paypal fee's.. Also will do $1600 + PP fees and include the tranny. 1. 421 68mm cheetah cub cylinders with pistons and wrist pin bearings $750 2. Hot Rods 4mm Longrod Crank like new 3 weekends on it. $350 3. Pro Design Cool Head with BB 18cc domes $170 4. RDZ 1-5 override with neutral down. PERFECT SHAPE! $400 6. Flow Tech 12oz Lightened Flywheel Good shape LOOKS NEW! $100 8. Majic Performance Lockup and polished Lock up cover. $300 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 11. Trinity Stage lV intakes for 38-40mm Carbs Also comes with a extra set of boots that fit a 34-36mm carb. No issues like cracking or anything like that. $140 12. Complete Electrical system from a 99 banshee. Comes with stator with modded timing plate all wires, Coil and a working CDI and wiring harness. Headlight harness was cut of for billet lights. $150 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 17. Axle Carrier from a 04 with brand new bearings and seals. $45 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 19. Complete set of Special Edition Yellow Plastics. Comes with a one of a kind Texas Chainsaw masacre Graphic Kit. Also comes with a custom made Chainsaw grille. This is the only Set of graphics and grille like this in the country. Plastics are in very good shape.. Not scratched up and beat like a trail bike. $300 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 21. Complete set of a-arms, spindles and tie rods. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 24. MSR Adjust on the fly clutch lever. Comes with a brand new MSR terminator Ceramic clutch cable. $50 26. Complete set of drag wheels and tires. Will come with a set of ITP rear wheels with Hoosiers and a set of 4" douglas front wheels with drag tires. Very nice wheels not bent or dented up. $350 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 33. Chrome Rear brake Lever and Shifter. VERY NICE! $60 34. KBC gunslinger helmet size XL. very good shape. $120
TTT..
Also going to sell my LID. Very good shape size XL. Use KBC's guide to fitment if any questions.. Helmet is KBC gunslinger. It is in very good shape not beat up.. $120 shipped!
Forgot to add this to the list.. Chrome Rear brake Lever and Chrome Shifter. Very good shape no rust or anything like that. $60 shipped
Yes it has bearings and it has been true and welded. It dosn't have the spacer as it was used with a cub. It is in all honesty like new. You can get the spacer from vito's. The carrier is off a 04 and has new bearings and seals in it.
Another UPDATED LIST OF WHATS LEFT.. 1. 421 68mm cheetah cub cylinders with pistons and wrist pin bearings $750 2. Hot Rods 4mm Longrod Crank like new 3 weekends on it. $350 3. Pro Design Cool Head with BB 18cc domes $170 4. RDZ 1-5 override with neutral down. PERFECT SHAPE! $400 6. Flow Tech 12oz Lightened Flywheel Good shape LOOKS NEW! $100 8. Majic Performance Lockup and polished Lock up cover. $300 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 11. Trinity Stage lV intakes for 38-40mm Carbs Also comes with a extra set of boots that fit a 34-36mm carb. No issues like cracking or anything like that. $140 12. Complete Electrical system from a 99 banshee. Comes with stator with modded timing plate all wires, Coil and a working CDI and wiring harness. Headlight harness was cut of for billet lights. $150 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 17. Axle Carrier from a 04 with brand new bearings and seals. $45 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 19. Complete set of Special Edition Yellow Plastics. Comes with a one of a kind Texas Chainsaw masacre Graphic Kit. Also comes with a custom made Chainsaw grille. This is the only Set of graphics and grille like this in the country. Plastics are in very good shape.. Not scratched up and beat like a trail bike. $300 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 21. Complete set of a-arms, spindles and tie rods. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 24. MSR Adjust on the fly clutch lever. Comes with a brand new MSR terminator Ceramic clutch cable. $50 26. Complete set of drag wheels and tires. Will come with a set of ITP rear wheels with Hoosiers and a set of 4" douglas front wheels with drag tires. Very nice wheels not bent or dented up. $350 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 And last but not least is the frame. It has just got back from the powdercoater last month. Has a 3 stage powdercoat on it. The base coat is powderchrome, the 2nd is a transparent Candy blue and the top coat is a sparkling clear coat. It looks wicked in the sun!. I do not have a title for this frame but i do have a bill of sale for it. Asking $450 shipped. Nice and straight with no stripped holes or anything like that. One of the upper plastic bolts had a bolt broke off in it and the PC'er forgot to take it out before PC. It is not visable but i still thoght it was worth mentioning.
TTT. Will do $725 shipped for the cub and $330 shipped for the stroker crank this weekeend!!
UPDATED LIST OF WHATS LEFT.. Clutch cover and reeds pending. 1. 421 68mm cheetah cub cylinders with pistons and wrist pin bearings $750 2. Hot Rods 4mm Longrod Crank like new 3 weekends on it. $350 3. Pro Design Cool Head with BB 18cc domes $170 4. RDZ 1-5 override with neutral down. PERFECT SHAPE! $400 5. Perfect set of Cases no breaks and port matched to a cub $200 6. Flow Tech 12oz Lightened Flywheel Good shape LOOKS NEW! $100 8. Majic Performance Lockup and polished Lock up cover. $300 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 11. Trinity Stage lV intakes for 38-40mm Carbs Also comes with a extra set of boots that fit a 34-36mm carb. No issues like cracking or anything like that. $140 12. Complete Electrical system from a 99 banshee. Comes with stator with modded timing plate all wires, Coil and a working CDI and wiring harness. Headlight harness was cut of for billet lights. $150 13. Tony Dukas Racing Reeds on ported Cages. Comes with Reed Spacers and allen head bolts $75 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 17. Axle Carrier from a 04 with brand new bearings and seals. $45 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 19. Complete set of Special Edition Yellow Plastics. Comes with a one of a kind Texas Chainsaw masacre Graphic Kit. Also comes with a custom made Chainsaw grille. This is the only Set of graphics and grille like this in the country. Plastics are in very good shape.. Not scratched up and beat like a trail bike. $300 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 21. Complete set of a-arms, spindles and tie rods. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 24. MSR Adjust on the fly clutch lever. Comes with a brand new MSR terminator Ceramic clutch cable. $50 25. Chrome 7/8" drag bars in good shape. $25 26. Complete set of drag wheels and tires. Will come with a set of ITP rear wheels with Hoosiers and a set of 4" douglas front wheels with drag tires. Very nice wheels not bent or dented up. $350 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 And last but not least is the frame. It has just got back from the powdercoater last month. Has a 3 stage powdercoat on it. The base coat is powderchrome, the 2nd is a transparent Candy blue and the top coat is a sparkling clear coat. It looks wicked in the sun!. I do not have a title for this frame but i do have a bill of sale for it. Asking $450 shipped. Nice and straight with no stripped holes or anything like that. One of the upper plastic bolts had a bolt broke off in it and the PC'er forgot to take it out before PC. It is not visable but i still thoght it was worth mentioning.
Heading to work. If anybody has any questions give me a call at 1-931-787-4022.
The clutch set up is pending payment. I do still have the MSR stuff and cable.
Fixing to go hang out with the Ol lady. If anybody needs anything or has any q's give me a call. I'll be up about 3 more hours. Thanks, Jeremy
No glad you mentioned that bro. It's for a stock carrier.
PM's returned. Also forgot to add to the list. Brand new billet gas cap from majic performance.. It is pictured above. $45 shipped Double wide foot pegs. Very clean painted flat black. $40 shipped
NP, thanks for the quick payment! As mentioned PIPES SOLD!@
Pic's don't do those plastics justice they are very nice!!
Back to ya .. Forgot to mention i work weird hours so if anybody wants to ask me a question or needs to get ahold of me feel free to call me at 1-931-787-4022 I'm normally up at 9am and awake till about 1 am.
replied
[/img]
Decided it will be much quicker to part it out. I do perfer paypal as i hate having people say they want something and having to hold it for nothing. I do ask that 3% is added to cover the paypal fee's.. With that said. I Will not be visiting the post office every day. I've decided that i will go every 3 days until everything is sold. I will give a discount on shipping if more than one item is purchased. All parts are from my VERY clean 99 banshee. I have really taken care of this thing. . So with that said. Here is what i have for sell. 1. 421 68mm cheetah cub cylinders with pistons and wrist pin bearings $750 2. Hot Rods 4mm Longrod Crank like new 3 weekends on it. $350 3. Pro Design Cool Head with BB 18cc domes $170 4. RDZ 1-5 override with neutral down. PERFECT SHAPE! $400 5. Perfect set of Cases no breaks and port matched to a cub $200 6. Flow Tech 12oz Lightened Flywheel Good shape LOOKS NEW! $100 7. Clutch set up.. This includes a barnett clutch system, Billet Clutch basket, Pancake bearing, Toomey 100% stiffer springs. new clutch arm, and pretty much all clutch components $150 8. Majic Performance Lockup and polished Lock up cover. $300 9. CPI Small Bore Out of frame Pipes in good shape. A couple inperfections on the undersides but no dents or anything.. Overal a 9 out of 10. $400 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 11. Trinity Stage lV intakes for 38-40mm Carbs Also comes with a extra set of boots that fit a 34-36mm carb. No issues like cracking or anything like that. $140 12. Complete Electrical system from a 99 banshee. Comes with stator with modded timing plate all wires, Coil and a working CDI and wiring harness. Headlight harness was cut of for billet lights. $150 13. Tony Dukas Racing Reeds on ported Cages. Comes with Reed Spacers and allen head bolts $75 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 17. Axle Carrier from a 04 with brand new bearings and seals. $45 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 19. Complete set of Special Edition Yellow Plastics. Comes with a one of a kind Texas Chainsaw masacre Graphic Kit. Also comes with a custom made Chainsaw grille. This is the only Set of graphics and grille like this in the country. Plastics are in very good shape.. Not scratched up and beat like a trail bike. $300 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 21. Complete set of a-arms, spindles and tie rods. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 24. MSR Adjust on the fly clutch lever. Comes with a brand new MSR terminator Ceramic clutch cable. $50 25. Chrome 7/8" drag bars in good shape. $25 26. Complete set of drag wheels and tires. Will come with a set of ITP rear wheels with Hoosiers and a set of 4" douglas front wheels with drag tires. Very nice wheels not bent or dented up. $350 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 30. Billet Headlights. Good Shape! $30 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 And last but not least is the frame. It has just got back from the powdercoater last month. Has a 3 stage powdercoat on it. The base coat is powderchrome, the 2nd is a transparent Candy blue and the top coat is a sparkling clear coat. It looks wicked in the sun!. I do not have a title for this frame but i do have a bill of sale for it. Asking $450 shipped. Nice and straight with no stripped holes or anything like that. One of the upper plastic bolts had a bolt broke off in it and the PC'er forgot to take it out before PC. It is not visable but i still thoght it was worth mentioning.
