yep , thats the old 700 piston port motor. like i said, try some of the companies i mentioned before, for performance parts. those are stock pipes that are on it now.(modified just a bit). half of the battle with a snowmobile engine is the clutching.peak horse power is supposed to be around 8100-8200 rpm for that motor. if its got a tach in it check your rpms to see if thats where its reving.(hold wide open under load/while driving) if its over or underyour peak hp range, you,re losing power and should make changes to your clutch set up.either add or subtract weight from your primary clutch levers.if you need any set up advice just pm me.
