so i am guessing you shut the engine off while riding and while it is still moving it makes a vibrating sound. Is the sound a chatter and you said it comes from the tranny, possibly.
i finally tore into the banshee and split the cases. it found that the 5th pinion gear on the main shaft had burnt spots (burnt oil) in between the shaft and the gear, and it didnt let the pinion turn freely...was thinking of replacing the shaft and gear as a whole but was wondering of just using some emery cloth to polish the shaft and the gear to see if it would work. what does you guys think. it doesnt look that bad but just need some insite.
thanks guys..pushing it around it does make noise. i thought it was the clutch at first i did soak them and inspect them but still the same. i started today and almost have it completly apart but, i need a flywheel puller. i took the whole motor apart cause i had a suspicion of coolant leaking into the cylinder. sure enough when i took off the head the gasket showed signs. i still dont know were i am going to buy the bearings for the transmission, but while i am in the engine i am going to get the crank trued and welded and also replacing all the oil seals and bearings, also doing the regular mods to the shift star and drum.
i didnt drain the fluid. i think it leaked out but not sure. stupid of me because i didnt check the fluids before a stroll around the block . it doesnt make noise in any of the gears just in neutral when the clutch is engaged.
hey guys, I have a problem with the shee. The other day i took the banshee out for a ride and didnt notice there was no oil in the trans. When i got back to the house I put it in neutral and let off the clutch and a screeching noise come from the trans. At first I thought it was the clutch but then i noticed that it feels like it wants to move in neutral when i let off the clutch. I inspected the clutch and basket all looks fine. I am thinking it is a fork but not sure, you guys got to help me, trying to get this thing ready for the dunes.
i have that problem about the gas being left on...my bike floods slightly and it takes longer to kick over...so i just turn it off every time i park it...i know i need to adjust the flouts but i always forget about it.. ::
if its grey then its ur clutch...if water was leaking into ur tranny ur bike would be over heating constantly and the oil would ba a white milky color...one of the reason it probably is coming out could be one of the vents are clogged...thats what happen to mine.another reason of it being grey is from it not been changed in a long time.
Yeah i had the same problem...i just replaced the water pump seal and bearing and the o-ring...my came out fine...just drained the trains a couple of time after running threw the gears a couple of times...thats my .02 cents :thumbsup: as for the output shaft seal cant help u there...do what others said and check the breathers to check that they are not plugged...usually thats where the fluid comes out of not the seal...to much pressure build up
Still got the shock if any one wants it....trade for a banshee shock or money...let me know...havent been able to responed to this tread lately..computer prob
