bansheebogger
1 Follower
About bansheebogger
  • Birthday 01/20/1997
  • Interests
    Girls , Cars , Motorcycles , Baseball.
bansheebogger's Achievements
  1. bike only overrides 1-3, when its supposedly a 1-5 ? probably bent shift forks ? when i lay off the gas it shifts like butter but when under load it wont shift .. HELP!
  2. bike only overrides 1-3, when its supposedly a 1-5 ? probably bent shift forks ? when i lay off the gas it shifts like butter but when under load it wont shift .. HELP!
  3. bike only overrides 1-3, when its supposedly a 1-5 ? probably bent shift forks ? when i lay off the gas it shifts like butter but when under load it wont shift .. HELP!
  4. Monkey Farm is where everybody is at , there will be a shitload of races this sunday. They will be meeting up at 12.
  5. Thanks Man. Very helpful, First question is answered but i need someone to answer the second one. Thanks.
  6. Hey guys, ive been thinking about some things and need help for some answers. Ive been riding since i was 11, and had my first banshee two years ago when i was 13yrs old. Anyways , me and my uncle about porting . Such as Port timing , and exhaust Degrees. I've been wanting to know about " What Exhaust Degree to use with a certain pipe,crank,etc.." I want to start porting engines myself, allot of you guys will say to get it done Professionally but sometimes there will be financial issues. Not only that but to have the knowledge at my age will be awesome . I know allot about these bike and about their engines, but i want to get deeper into the sport , i want to build fast bikes and learn off of them. I just need someone to give some input on port timing , and exhaust degrees. I already know benefits and all the fancy stuff about it, since ive been porting blaster cylinders to practice. I know its not all about removing cast flaws, and metal. Theres alot more to it. Another question. Im doing an off of frame build on my banshee . Ive got a 4mil crank with 110mm rods. And some Stock jugs that are resleeved with 69mm sleeves. Jugs have a Trinity IV Port job. this setup will give me 433 cc's . Will i have to run a lockout clutch? Im going to be racing a bit but riding more trails, and Open space riding. I only weight 150 Lbs. Also with the setup i have do i have to run blaster pistons? Or just Big bore pistons. Since i dont have longrods? All this may sound retarted to you guys but im only 15 and want to have great knowledge by the time im in my 20's lol. Any input or advice will be greatly appreciated. Joey.
  7. Just bought my first Dragger. 421 Ftw.
  8. This guy is a douche lmfao. Not all floridians are like that lol. Im from Miami. Flowrida this is not a good way to enter a forum.
  9. Any advice? Anyone?
  10. Hey guys i havent been here in a while because im Rebuilding the shee. Ive posted a thread at blasterforum already but decided to come over to the banshee boys to ask a few questions. I currently rebuilt my blaster motor Its got a aggresive mx port, Toomey b1 pipe, vf3, and a shaved head. Im running a stock carb because i need to buy a throttle cable for my 34mm keihin. Heres the deal once i crank her shes like a car , she tends to have a high idle then come down to a perfect idle. Note: I have all my idle adjustments screwed all the way in. So this means shes idling all bt herself! i have a 32.5 pilot and a 310 main. Main jet is fine but i have sputtering problems at a 1/4 throttle! I checked for an airleak and shes fine. I need help . Any input would be greatly appreciated. Thank You. Joey.
  11. Hey guys i bought a bike for a 1000 and came with bills pipes heard of them but never ran them. Are the any good. I believe i have the newer ones that were made. And i do trails and some open riding are they good for my type of riding??
  12. also the carbs arent syncronized is that a big problem.. stupid question but im only 14 and only have a good 4 years messing around with bikes
  13. thanks for all the replies im going to give it it a try y do u guys think it keeps backfiring
  14. the tors is remove but it only has the caps for the top of the carb removed, but not the idle screws on the sides..
