FASTOYS
HQ Site Sponsor!
    2
Everything posted by FASTOYS
  1. Sold pending payment . Next inline if it falls through is Flea49.
  2. It may be tough who knows BUT everyone does not want a Drag motor (Cub) also. Got to keep in mind these cylinders will have a very broad powerband and come with pistons, all gaskets, fresh bore/hone, powdercoated black (not bare), etc. with no wait time on porting. By the time you get a cub and add pistons, gaskets, stud extenders, waterplugs, gaskets, powdercoating, etc. you are already way more than $1000. We also have a customer with this same porting who runs his buddies 350 cub and the Dune/Play port is right there or just in front. Several people on here will vouch how these cylinders run ....Duner440, Badassbanshee479, Rippen, Bigred350x (as his 4mm cub was getting beat by similar cylinders, i know, i know Red, yours wasnt tuned. jk lol).
  3. Sorry, forgot to post that it is a 68mm 421. Going in this order, if i dont hear from badshee today then your next inline flea49.
  4. I have a customers used 4mm cub setup for sale that has a $300 port job from Dan Hull at A & S. Also have 4mm crank trued/welded with Max Load bearings on BOTH sides, stud extenders, water plugs, new base gasket, and 2 used pistons. All this will go for the low price of $1300 plus applical fees ( shipping, paypal fees, etc.). I have checked this stuff out and it is in good used shape and came off a great running engine. Customer decided to go BIG. I have no pics as you all know what a cub looks like . I assure you it is in good shape and many will vouch for my credibilty. We also have new domes available if needed at additional cost.
  5. If your talking about the Pro wedge IIs....we carry them. Im not sure if Chapparal sells them or not.
  6. I may have used ones and im pretty sure we have new studs. Give us a holler.
  7. Spring bolt torque is 7.5-8 ft lbs. 7.5 i believe. adjust the center screw until the lever on top of the case lines up with the arrows on the case in front of the sprocket area. I like to keep it alittle torward the stator side.
  8. Why heck yes. Everyone thats anyone is gonna be there right?! If nothing else at least for the day.
  9. Loco, how could you and Bigboy see dust with your beer goggles you had on anyway?? jk "I'll have another"
  10. Wow, thanks lastleg glad you like it . Man we did that one about a year ago. Sounds like you got it running well though. You and soupbox gonna make the spring ride at LS?
  11. Altvator, give me a holler if you need help with it as i tried to call you the other day but dont have the right #. Bigboy pretty much had it correct. Set the idle screws so the tool reads the same , then rev it up and hold it about 1000 rpm higher steady and set the pull with the carb top adjustes. Torque em down, double check and your done. Real easy.
  12. R/atv, ive got a couple of customers heading out there to Glamis on the that weekend. Keep an eye out for a black Banshee/maroon and a white/black Banshee. Have fun and be safe!
  13. Happy Birthday guys!! Drink one for me. :beer:
  14. Bansheeman, the reason it broke is becuase you set your torque wrench up for 25 ft lbs.......!!? I believe they are only around 7-8 ft lbs for the 6 clutch bolts. Is this what you need?? http://www.farmandsandtoys.com/partdetail.asp?partid=108 Even have new bolts if needed. Give us a holler if you need help !
  15. Happy belated B day Mr Germain the 2nd. :beer:
  16. We have sold some to farmers and an occasional sport quad guy and nothing but good reports. 6ply, good heavy tire so no flats! Good traction and seem to last a long time. Not to high a $$.
  17. I should have an extra , you pay shipping and its yours if that will help you out.!!? Pm me and let me know.
  18. Been Very busy, Yamaha04 and about 18 others were called back the very next day as Friday was a blur.
  19. Lookin good Dan! :thumbsup:
  20. 3rd place .......not near as good.
  21. Should of been able to just connect the harness side red to black with a pigtail and 2 connectors. Glad you got it figured out.
  22. True, just some people look for alittle cheaper alternative with the 4 snows.
  23. The $700 sounds alittle steep but if you need a crank then i would recommend going 4mm especially if your gonna port for it at the same time. The arms and shock deal sounds decent.
  24. We sell a few of them and they work good on snow and even better on medium/soft dirt drags!!
  25. Its been awhile since ive done one but i believe you take the red wire and connect it with the black wire. Then you can use the factory kill switch on the left handlebars to shut it off.
