2
Everything posted by dajogejr
If there is no master link, which...I'm assuming you looked for one, there is only one EASY way to do it, without getting a chain breaker...etc. Loosed up the ass end, turn the adjusters all the way out (Loosens the chain by sliding the bearing housing forward) and walk it off your rear sprocket, then front, then over the tire... Are you looking to take it off and clean it...or replace it? Clean it...you're good from there. Replace it? Any new chain will have a master link in it. Some may have to cut a few links off, depending on your gearing. Any reputable motorcycle/quad dealer/shop can tell you how many links to cut off. Remember, if you're replacing the chain, replace the sprockets, too. Worn sprockets can quickly ruin a new chain, and vice versa...
I haven't gotten the throttle yet...a little problem with payment/shipment issue. I haven't gone out and bought a new cable yet, even though Motion Pro tech support told me their twist cable will NOT work with any thumb, OEM or aftermarket, I'm still leaning on a prayer... Only way to know for sure is when it's here...and ready to go on. I'll post back once It's in my greasy paws...
I took my hose off my shee for my T5's...and reversed it. Now...the part with the coil is on the bottom where the hose goes into the cases...and twisted it just a hair. Just a bit of clearance, and the spring around it for good insurance...
Be sure to roost a 4 stroke or two...just to prove they're biting good...
Darn....been looking for this solution for a while... Time to get out the zippies. I'd bet you could use some kind of muffler metal strap tape, in absense of zip ties....
Interesting find...Fixit. My only thing is...since he mentioned power for trail riding...the truck/camp isn't always so close. You're gonna suck down some serious juice with those babies on... I plan on keeping the carbs stock, with possibly boring them to 28mm...at most.
Yeah...he said they had 100HP shees holding up with this clutch. Recommed using all 6 springs, and you're gonna have to have an ez pull lever, which...I already do. Since mine isn't putting out half of that....YET....I'm sure I'll be good for a while. Again, super nice guy...and very, very knowledgable!
Yep...sure did. Said I was the 2nd or 3rd person you recommended call today...what kind of kickback you gettin...anyways? Told him you and stclark told me 'bout him. I assume that's your bro? Also...he said...you talk to Tyler on Banshee HQ. Was a big yep...sure did... Told him to head over here and drum up some business.... Can't wait to get this in... Always good to hear about good guys, good service!
Super duper nice guy. Thanks so much, Tyler.... According to him, he is using stock factory FZR 600 Fibers, Barnett HD Springs and steels. 95.00 plus shipping. Also got some Engine Ice to cool the lad...one bottle will be enough...17.00. He also gave me some tips on the clutch, what to look for...and to look at the shift star, etc. Also tips on "burping" the air out of the system when putting in the "ice". Thanks again...Tyler. I will most definately be doing business with FAST Racing again in the near future...
Geez....very good point, Sandstar. It's so easy to forget and sometimes overlook the beginning steps...huh? Good point!
I'm sure of that... My wallet hopefully won't feel the sting... Thanks again, Tyler. Are they open now?
You're really trying to do something a Banshee isn't designed to do. You can get good bottom, but it'll sign off top a little more. You can get Phenomenal top...but, low will lack. The purpose of this site is help one another, shard mods, stories, ideas...and friendship...not to try and accomplish the impossible.. I'm not trying to get you down or discourage you...but, you're asking for a lot of bottom and at the same time keeping a screaming top end for drag racing... Bigger carbs will help top, so will drag style pipes. But, then...if you get a low end/mid end port job, your not getting the most of the pipes and carbs you just bought. See what I mean? You're going to have to make a compromise somewhere, that's all I'm saying!! There are several reputable porters out there. Passion, Eric Gorr, Trinity...etc. Talk with each of them...
Too bad RMATV is the only place you can get 'em, short of getting ripped for one on ebay. They've been out of stock for almost two weeks now.... http://www.rockymountainatv.com/Product_De...tv?pid=00055599 As Tyler said...I'm giving Fast Racing a call today about the street bike setup!!
The prefilter won't make a bit of difference in jetting. It just keeps sand/mud and some of the water off it. I'd clean it to be safe...always do the cheap/easy stuff yourself. Saves time, and possibly embarrassment...
You can't move it. A mod (Moderator) can... You can try sending a PM to one of the mods...asking them. Or...chance it they run across this and do it for you. If you look at the different forum areas, at the bottom of the description you'll see "Led by". those are the particular moderators for the forum.... Good luck!!
Switched throttle cables, as in left to right? That shouldn't change how the bike runs at all. It might idle higher...if the cable is being pulled...but that's about it. There is a little tube that goes from one carb to the other. It's part of the idle speed fuel enrichment/choke mechanism. Make sure that tube, probably about 2 1/2 inches, is connected to the carbs and sealed. This might sound dumb...but how dirty is that air filter. Did you check all the TORS wires/connections? Also...just for giggles. Close the Spark Plug gap to .020. See if it runs better at low to Mid RPMs. If so...that indicates a stator problem. Main jets won't help off idle. That's a combo of the pilot jet and air screw settings. With those pipes...I'd get 27.5 pilots. 25 is stock. Make sure the needle is in the right clip. Turn the air screws all the way in until they are GENTLY seated. No need to force them, they can be damaged that way. Count out 1 1/2 turns out from the fully seated position. Out is leaner...in is richer. Just gotta have patience. I bought mine off a bud two months ago...jetting was all fouled up. I got mine darned close, if not dialed in and it took me about 4 to 5 trips to a local field and a whole lot of drag racing my buddies. well worth what I learned...though.
Yes...hit the "Don't add" button for me...please... WTF!!
Those Toomey kits are a little lean, IMO. Stock needles have But...if 320s were that fat, I agree. Start with 280s...go from there. I'd get 270, 280 and 290 jets. I'm in MI too. Most of the state is less than 1000 ft above sea level...a few spots from 1000 to 2000 ft. make sure the needle is in the 3rd groove...too...
How many grooves are on those needles? Stock needles have 5 grooves. 3rd groove would be correct. The Dynojet kit that comes with the toomey's has 6 grooves. 4th groove would be correct (counting down from the blunt end.) You really need to get new plugs, I'd buy 3 sets of them. they're less than 2.00 a piece at AutoZone. I'm running NO airbox, K&N filters, Boyesen Reeds and T5s. Slightly above sea level. 310 Mains. 27.5 Pilots and 1.5 to 2.25 out on the air screws. Does it still have the TORS on it? If so, I'd check all the wire connections, making sure one of the wires isn't bare/shorting out. Next...make sure there are no air leaks at the carb/intake/crossover tube/air filter boots... You mentioned running out of gas. Now's a good time to remove each carb, clean it good with compressed air and a fine strand of wire. remove the pilots and mains too...clean those passages. If you sucked in some dirt...from running out of fuel, the smallest speck of dirt can play havoc on your jetting. I accidentally ran mine out of gas...first ride this year. Fouled one plug...bike ran like crap...till I filled 'er back up:) Luckily, I was only 50 yards from the truck... Oh yeah...what kind of oil and ratio are you using?
Live in MI myself, Metro-Detroit area. Stock carbs, K & N clamp ons (Pods), Boyesen Reeds and Toomey T5s. I can't promise you my jetting is not 100% perfect...but, it's darn close. VERY close. I run 310 Main, 27.5 pilots. Toomey/Dynojet jet kit needles in the 4th clip (these needles have 6 grooves instead of the stock 5 groove needles) Air screws have varied lately...you know it was 40s two weeks ago...today, upper 60s. That's MI for you. I've been going from 1.5 to 2.25 turns out on my air screws. Also...make sure your floats are at 21mm...
Maybe... Could be a combo... Leaner on the needle. Adjust the air screws an possibly richen the pilots. You might get better help if you ask a mod to move this to the exhaust/jetting forum. When I got my shee a few months ago...jetting was all hosed. My specs are in the sig. I followed this article as a guideline. I wouldn't say it's 100% correct, nor are they claiming it to be. But...it most definately get you in the ball park... http://www.dfn.com/benkaren/jetfaq.html
If I spent 30K on my shee...chrome as far as the eye could see...I STILL dont' think I'd pay that much for friggin lug nuts.... Hell...you could probably buy Acorn style and have 'em dipped for a fraction of that... Suck on deez nutz is all I can say about those lug nuts...
Probably too late now...but, at work tomorrow...I'll give him a call...printed this out for reference and the nubmers! If he can do it for 95 or 100...that's a steal... I'm getting tired of "Close" racing with my 450R buddies....gonna clutch it, see how much better it is, then...probably Eric Gorr or Passion Port job sooner rather than later. Been picking up a ton of side jobs, so...gonna get it done while I got the cash... Where is Jeff @ Fast Racing located? Thanks a bunch for the lead...I greatly appreciate it...loco!
Alrighty boys...sorry to dig up this old one. Going to get the Street Bike setup, can't stand waiting any longer for the Tusk to be in stock at RMATV... So, the springs, Steels and Fibers will all work in the Shee? Thanks again!
Bubba's got more natural talent and speed than anyone I've seen in years...possibly since Jean Michele Bayle.... Outdoors maybe a different story....Bubba is riding the 250, last I heard. RC is going to ride the 450, since Tortelli is doing all the R&D work on it right now...a la...making sure it'll hold up. They're coming to Pontiac this weekend...my area. Can't wait... If you remember, RC's first 2 years on a 250 were rocky at best. Then...he came alive. MC was the indoor master...but, no one can dispute RC is the outdoor king. I don't know if Bubba can even pull off a perfect season, let alone 2. It's really too bad there haven't been too many good races in the past few years. Back since MC...it was pull the holeshot, and checkout. Boring to watch. I still love the old Bradshaw/Stanton days. Banging bars, brake checking...and the whole lot. Those were good races. I'd love to see a good slam 'em and hand it to em race with RC, Bubba, Reed and K-Dub. I've been an RC fan since his first race, wearing #70 on the Kawi... Can't stand Reed. He's just...bland. MC always had a cool attitude and knew what to say. RC is getting better at his speaking... If Bubba stays healthy and keeps the rubber side down, he's going to break the indoor record. Gonna have to wait and see for outdoors... Nothing against Bubba....but I hope RC turns it on and whips up on 'em in Pontiac this weekend...The flying red freckle needs a break.
