BrockMoto
Everything posted by BrockMoto
  1. ^^^ good info here!
  2. Check the cable, and make sure its oiled too, dirty slides are what usually cause this tho I'd check em again and if they are dirty check your filter for rips
  3. Give Kevin a call, he can answer all your questions
  4. Did you check your float height? Is the float stuck?
  5. I know this is an old post... but I'm curious of everyone's thoughts on PT mids with a serval as well as 916's... I like both those pipes but don't want to run them if pc is way better
  6. what are your plans for functional changes?
  7. This is a must have for me! Can't wait
  8. Sounds like an air leak developed causing a lean condition,I would split them for sure, and do a leak down, before running it again
  9. Thanks tyler bought a 155, 160, 165, 42,45,48 I'll let ya know
  10. I am completely lost when it comes to jetting, so any help would be awesome. I just bought a complete motor from Zilla it has some porting but idk the numbers, I am also running keihen D slide 28mm with no air box uni's, FMF fatties, running 91 or 93 if I can find it and 32:1, I am at approx 1000ft above SL.... its hot as balls here right now (upper 90's) but isnt all the time what should I do so I can ride now and when it cools down too Thank You!!
  11. if i had the cash id be at your door tomorrow. bump sweet biike
  12. I just dislike the smell but good idea, I saw a pic on here earlier where a guy ran it up the bars out the side of his hand guards so he could see it squirting
  13. Having your jetting dead on will keep your temperatures down, which does away with overflow, but even if your jetting is perfect, a long day in the sand at 95 degrees on a stock cooling system... right jetting or not shee's getting hot I do not use a coolant bottle, only issue is make sure you run the line away from your hands/ legs and exhaust
  14. Got the cover today, Thanks Phelps!
  15. I'll take a stator cover, send me your info
  16. It really is ridiculous
  17. suspension upgrades are a good thing, especially on a banshee, first kick is a good thing but you should check the compression anyway when you go see it, he could have ran it for an hour before you got there you never know. and as far as plastics go use the search function to check what has sold here to get an idea on what you'll get for your money Oh and GO THUNDER
  18. I think there is one in the for sale section right now, just went up
  19. agreed, Chartiot
  20. http://cgi.ebay.com/ebaymotors/LOOK-GORGEOUS-TRX-250R-ESR-310-TRX250R-LONESTAR-BANSHEE-YFZ450-CLEAN-TITLE-/190687858804?pt=ATVs&hash=item2c65e1d074#ht_500wt_1182
  21. BrockMoto
    421 serval
    3 is a little steep for me man, sounds like a stellar motor tho
  22. Would you ship the bottom end?
  23. BrockMoto
    421 serval
    Yea I text him, he sold it.. Thanks tho
  24. BrockMoto
    421 serval
    Looking for a 421, complete or very close, I have carbs... Let me know what you got
