r6rider04
Everything posted by r6rider04
  1. i appologize they are actually 34mm, but what kind of porting should be done to run this set up?
  2. ok thats where i used to park once they closed cohen egg farm, so i'm pretty familiar with the trails, thank you. i wasn't sure if you guys were parking on rt. 35 again... not sure how much riding is left this season but hopefully i will run into you guys down there
  3. where are you guys parking at dayton, i miss that place, used to ride there all the time up until they cracked down on it, i only live an hour away, let me know please, awsome place to ride. Thanks in advance,. Brian
  4. a friend of mine has the alba 36 mm carbs with the intake manifolds and boost bottle sold as a kit, brand new still in the box, for 200 bucks, about 600 from alba. my question is, is this a worth while while investment? I've got a +4mm stoker, bored 30 over v-force3 reeds, toomey t-5s, mild porting, and milled head (stock carbs) and pro-flow k&n filter set up. any opinions welcome, thanks
  5. thanks again guys i'll mess with it tomarrow luckily its still too muddy to ride anywhere here in maine
  6. whats a good indication that a coil has gone bad?
  7. wow learn something new everyday thanks man
  8. i've got toomey T5's.. but you don't think i can hit redline?? that woul; be great i've been pussy footing that thing since i got it back together i'd love to see what reall has thanks guys
  9. i know there is already a thread about this. I didn't want to steal the thread.. can you buy them or do you just have them done, and whats with the round carrier (aftremarket)?
  10. prolly a dumb question, but ever since i got this installed it seems like it revs up really fast, just don't want to over rev. how do i know when it's close to it's limit, it just sounds totally different than it did before the stroker
  11. yeah i think i could have reeled him in too but we were on a short gravel road i couldn't evan get into 6th gear we'll see on the ice in a week or so still breaking in the fresh stroker and top end then...
  12. i have dumped a few bucks since then, 4mm stroker and ported more i'm not too worried anymore
  13. no we weigh the same i'm pretty sure i can get him i just can't hook up, never raced him on asphalt that might be different
  14. yes he did sorry about that
  15. just curious if i should have been beating him or not. He's only got a pipe, jetting and an aftermarket cdi (extra 1000rpms), at the time i had toomey T5's reed spacers k&n filter, and mild port job
  16. i'm with you on that hightemp mine is awesome, still only have about 1-2 hours on it though
  17. i don't know what i'm basing my oppinion on but that seems high (180psi) is that with stock head? because i've got the same crank and mine was 152 psi on both, but that was before i evan started it after rebuilding it would that make a differance?? like the rings not being seated yet?? i don't really know i'm still new to 2-strokes
  18. thanks guys i guess this month will be reeds, eventually i'll get all the things i want
  19. yeah i'm with zep right in front of the fuel shut off above the left side spark plug, mine had the same symptoms and unpluging the tors fixed it
  20. i used to spank my buddies raptor with my shee, mostly stock, pipes, reed spacers, k&n filter
  21. right now i'm running 93 octane pump gas with klotz R50 oil.. spacer is on top (thicker head gasket)
  22. yeah jets are pretty cheap i got them for 2.50 each
  23. i'm running 380 mains mild port/polish, 4mm stroker, bored 30 over, reed spacers, k/n filter with toomey t5's and runs perfect, still breaking it though haven't done the WOT 6th gear test yet
  24. Right now i have a fresh 4mm stroker bored 30 over, mild port/ polish, toomey t5's, proflow/k&n filter set up, reed spacers,and barnet clutches... I'm thinking of a Noss head or V-force reeds, what do you guys think, can only afford one at this time which is more worth while or i'm open to other options too.. On the subject of the Noss head what domes are recommended with these mods I live between 0-600 feet above sea level thanks guys.. Brian
  25. i just got my 4mm stroker together and it goes great (now that i figured out 300 main jets were way to small ) any way, i have stock head right now with a "stroker" head gasket, not sure if that is what you guys mean by spacer plate, but it was $52.00 i checked compression before i started it ,about 152psi for both sides haven't checked since rings have seated, very happy with it i can stand it up in 6th with no clutch love my shee
