PUSH THE THROTTLE
Everything posted by PUSH THE THROTTLE
  1. I'm guessing your connections aren't tight and check your grounds otherwise make sure you have the key on and the run switch on run. There's no reason why it won't run with the +5.
  2. I say keep the basket and get yourself a stock pressure plate and hub off of ebay and run the tusk clutch. Sell the new pressure plate you bought and you'll be just fine and it'll be cheaper.
  3. Welcome to the HQ
  4. http://ericgorr.com/
  5. When you say good what do you mean? Why are they better? Life???
  6. Like this: http://www.denniskirk.com/jsp/product_cata...leafCatId=11606
  7. Iridium is the material used, they are NGK
  8. You Bible thumper.
  9. I used them before my rebuild and may use them again sometime, too costly until I dial in my jetting. I really didn
  10. Looks like Dunedemon answered the question about the pressure plate I had. I
  11. OK thanks for the help Nightrider I appreciate it. My info on Hybrids came from the shop talk (I think that
  12. I like my Elkas a lot. I like to have everything be the same so if I was to have TCS rebuild the rear I
  13. I heard that to, (have you been listening to talk radio???) it seems the reason they can
  14. I like the avatar better
  15. I haven't dynoed mine but if I add up everything correctly I'm right around 304.732419867HP
  16. Bye
  17. I didn't see this part of your post, I hear ya but my $200 port seriously hauls ass now, it's the torquiest banshee I've ever been on, smooth from idle on up.
  18. That's a valid point. I want to read the review so make sure you post it. The best way to eliminate spin that I've found is to use a big front sprocket. What kind of gearing are you running 1800bigK?
  19. They are on order, it
