grounded
    2
Everything posted by grounded
  1. Should i try moving the needle position all the way up?
  2. CEL needle on middle clip, 50 pilot, 172 main, mild port, 19cc domes, +4 timing ridden in glamis, seems like this is lean compared to some specs Ive read here. but , it feels pretty rich up top, I threw a 170 in it , but have'nt rode it yet, gonna check it at the dunes. just wondering why i'm at a 170 and everyone else seems to be around a 180?
  3. I put an EBC in mine after my barnett went. It uses an extra plate, and has a stiffer feel. This will be my 3rd season on it.
  4. Add one more. Mine is a 370 long rod, mid- dune port, 19cc domes and a 2 into 1 trinty setup http://www.bikepics.com/pictures/931341/
  5. Your right on that. My guess is it will keep happening. These are the type of people who only give a shit about themselves. Piss on it.
  6. Well I guess you have your experience and I have mine.
  7. Sure, whatever you say. AND I have never drag raced any 450s up olds with a single carbed 350cc set up. I guess a 450 has too much top end
  8. Sorry , that carb set up does not lose any top end to stock carbs
  9. What size haulers are those on B-rider21's ride? I'm running 20x10x10 s , I know I'm spinning too much, instead of re gearing , I wanted the haulers for more ground clearance and better ride.
  10. After seeing this post , I went to jegs and ordered one. I was going to do an in-line gauge , but really wanted a cleaner install. Anyway , this is the one I got: http://www.jegs.com/webapp/wcs/stores/serv...amp;showValue=1
  11. Its really too bad. Met some of these guys who do the summer drags at a house party a few months ago. Seem like a real rowdy /sloppy drunk group . They gave me an invite to check it out. But, I'd feel a little nervous bein' the only white boy out there.
  12. been thinking of adding methanol injection in my turbo regal, but I have easy access to 100LL and have no idea where to get the alky from.
  13. I have a red one mounted right under the over flow tank, , it brightens up the shock and swing arm nicely
  14. http://www.youtube.com/watch?v=7DaiW_R6ikk...ted&search=
  15. Anyone who needs one can pick it up , I'm in phoenix area.
  16. Where'd you guys go riding at? Weathers been decent............ might need to knock the dust off the RM w/ you guys sometime!
  17. Sounds like a head gasket symptom ( drain the oil)
  18. Renthal only makes the bare aluminum for banshees( as far as I can find) I do have a black renthal on my dirt bike and it looks awsome. I'm pretty sure its anodized. The sprocket hub I have is an aluminum lonestar so I wo'nt be coating that.
  19. Yup, I'm thinking it should look pretty killer.
  20. My buddy has a powder coating setup in his garage, alot of his stuff turn out good. He offered to powder coat any thing that will fit in the oven. I want to try the rear spocket in a gloss black , I,m thinking it should hold up well, or at least for the life of an aluminum sprocket.
  21. Riding out in the dunes(20-30 mins) pretty hard I can touch mine after about 10 minutes, on my old warrior on the same ride , it stayed too hot to touch for at least 30 minutes. Same oil was used and both bikes were running perfectly, I guess if you really abuse the clutch you can get the temps to soar.
  22. Joe is the guy with my shock right now, a lot of people have been happy with the work done over at GD.com.
  23. I never had a good set up with race tech on my dirt bikes, after multiple times back for springs and valving , I had motoworks set me up and was happy with them , but they won't touch a stock banshee rear shock for some reason.
  24. Right now my paddle tire is still on it, but the one in the pic should be a michelin m-12, they seem to work great on the hard pack / over watered tracks out here
  25. Well I wanted the taller tire for less spin . Would be for Olds hill , but if I'm going to load it down too much, I will stick with the 8 paddles. Really a 21 x12 x 8 8 paddle vs a 20x10x10 8 paddle is it worth it?
